engine knocking...Anyone know why?
my engine is knocking pretty loud and i cant find out what it is?Also, when i press the gas peddle too quick my car bogs and almost dies, simetimes it does die. Any suggestions?
You probably need new bearings. The knock is usually a a sign of worn out bearings (rod knock). I've had it happen that the worn bearing would hold onto the crank and stop the engine from spinning. That means you are close to throwing a rod, which will destroy the whole engine. Inspect your crank when you replace the bearing, it might be scored by now.
