which is better rc saturated or peak and hold injectors for itr compression
Old Nov 29, 2007 | 06:56 AM
Eklsv-t's Avatar
Default which is better rc saturated or peak and hold injectors for itr compression
im running 550cc and not sure what it is. i blew my ls vtec turbo motor and going na. i sold 550cc and not sure what rc 310cc to get for my high compression na built. Which is better peak or saturated. Do I get obd 1 or obd 2. My ek is obd 2 with obd 1 converted p28 ecu.
Old Nov 29, 2007 | 07:16 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: which is better rc saturated or peak and hold injectors for itr compression (Eklsv-t)
1st question is do you have a resistor box?
If not then saturated or high impedence is what you need.
A resistor box is required is for low impendece or peak and hold.
Old Nov 29, 2007 | 08:45 AM
Eklsv-t's Avatar
no resistor box
Old Nov 29, 2007 | 10:09 AM
mar778c's Avatar
Community Builder
Default Re: (Eklsv-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eklsv-t &raquo;</TD></TR><TR><TD CLASS="quote">no resistor box</TD></TR></TABLE>
Saturated it is.
Old Nov 29, 2007 | 12:04 PM
95 integra's Avatar
Default Re: (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">
Saturated it is.</TD></TR></TABLE>
It really makes very little difference on that size injector, so just run the plug and play vs having to wire in resistors.
Old Nov 29, 2007 | 02:38 PM
New2theDC2's Avatar
Is needing a resistor box based solely on whether the injectors are high or low impedance, or are there other factors such as what ecu is being used or whether the car is obd1 or obd2?
Old Nov 29, 2007 | 05:31 PM
frostyrb's Avatar
Default Re: (New2theDC2)
I think all honda ecu's read in high impedance, so if you get low impedance injectors you will need an injector box. OBD0, OBD1, & OBD2 makes no difference. They all want to see 12ohms.
LSej1
May 20, 2008 09:13 PM
Eklsv-t
Dec 5, 2007 09:55 AM
Adam West
Dec 9, 2005 07:16 AM
Sassafrass
Oct 9, 2004 09:58 PM
NuclearB18B
Jul 10, 2003 05:59 PM
