PLEASE HELP!!!!!
Old Nov 29, 2007 | 06:46 AM
98jdmek's Avatar
Default PLEASE HELP!!!!!
ok my distributor went on me the other day right after i put sea foam in my motor to clean it out. i put my friends distributor on my car to make sure that was the problem and the car started right up. 2 days later i got a new distributor and put it on the car and now the car sounds like it has no compression. it turns over really fast and it sounds the same without the spark plugs in it as it does with them in. i havnt touched the car since i started it up with my friends distributor and it ran fine. i cannot think of wat could possibly hav went wrong because i didnt do anythhing to the car. btw its a 2001 ls motor
Old Nov 29, 2007 | 11:22 AM
98jdmek's Avatar
Default Re: PLEASE HELP!!!!! (98jdmek)
any suggestions
Old Nov 29, 2007 | 11:35 AM
hatchling37's Avatar
How's your starter? You might take it off and have it tested...
If it sounds like you have no compression, that's not good. Pull off your oil cap and look inside while you have someone try to crank it. Check to make sure the cams are turning. If they're not, obviously stop, since you have some work ahead of you. Hopefully it's not your timing belt, but weirder things have happened.
tien285
Jul 31, 2009 07:23 AM
everlight44
Mar 12, 2009 07:57 PM
rodvang
Jan 9, 2008 05:45 AM
98jdmek
Nov 29, 2007 01:34 PM
EXOSPEED:SHARK
Jan 3, 2004 07:57 PM
