obd0 b16a coolant drain bolt?
I searched and only came up with the location for newer engines with the coolant drain right above the engine stamp on the block. I'm doing my thermostat and waterpump tonight.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harlowe »</TD></TR><TR><TD CLASS="quote">The radiator drain plug is a little plug on the bottom of the radiator. It's a little plastic plug, no bolt.</TD></TR></TABLE>
I realize that... I am asking if/where the drain bolt is located on the block.
This is what I am looking for (from an ITR) but the obd0 b16 does not have it in this spot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">Why the hell do you need to drain it from there anyways??</TD></TR></TABLE>
Because he's doing his waterpump and he doesn't want to splash it all over?
As far as where the actual drain plugs are, I'm not sure. I'd check the back of the block under neath the waterpipe.
Powered By Garrett
Jul 17, 2008 06:05 PM
Black Paper Diary
May 25, 2006 05:51 PM
