Replacing radius rod bushing
Old Nov 28, 2007 | 08:13 PM
LukieLuc's Avatar
Default Replacing radius rod bushing
Okay, usually when i drive i hear a clunk sound coming from the front end when stopping and going. so my car was on a lift the other day and i noticed that i could shake the radius rod on the passenger side of the car, so i figure its time to change the bushing.
I wanted to know if you guys could tell me where i can get some fresh bushings and if anyone had tips on replacing it and tq specs. thanks
Old Nov 29, 2007 | 01:39 AM
SnlpeR's Avatar
easy to replace
i put some prothane ones
two bolts that bolt to the bottom of the LCA
and one bolt in front of the radius rod
unbolt the one in front of the radius rod first
and just make sure to torque that front bolt properly because as youre tightening....you will be squishing the bushing together
Old Nov 29, 2007 | 03:19 AM
mattsnooz's Avatar
Default Re: (SnlpeR)
nice. I'm doing this , this weekend. My bushings are cracked all over the place.
thanks! So don't go with oem or what?
Never heard of prothane, will they last longer? How are they priced? Are you going to do all of them or just the ones that are mangled? I forget off hand (and yes I guess I'm being lazy but if anybody knows off hand how many are in my 93 prelude, that would save me a bit of searching, as I'd like to do all of them at once.)
Old Nov 29, 2007 | 04:57 AM
LukieLuc's Avatar
Thanks, Snlper
Where can I get prothane bushings though?
Old Nov 29, 2007 | 05:21 AM
mgags7's Avatar
http://www.suspension.com
Old Nov 29, 2007 | 09:06 AM
93sivtec's Avatar
Default Re: (mgags7)
Make sure to get re aligned because the radius rod controlls caster I belive and could possibly throw allignment out when replaced.
Old Nov 29, 2007 | 09:50 AM
LukieLuc's Avatar
Default Re: (93sivtec)
am i looking at this http://www.suspension.com/Honda_Prelude.html the 4th column?
Old Nov 30, 2007 | 04:54 AM
92hondalude's Avatar
Default Re: (LukieLuc)
16.7103
$18.00
1.0#
kornerk12
Jul 1, 2009 03:54 PM
ih8sndq
Mar 9, 2006 04:06 PM
Eddiebx
Jul 23, 2004 06:46 AM
VWkila
Apr 20, 2004 06:25 PM
servion
Jan 21, 2004 09:56 PM
