best way to setup custom breather kit??
Old Nov 28, 2007 | 03:30 PM
Samuels's Avatar
Default best way to setup custom breather kit??
I was gonna put the plug in and run 1 steel braided line from the back of the block and have 2 steel braided lines running from the front of the valvecover into a custom built can.
Would it be better to run 2 lines from the back of the block and have all 4 in the can?
What should i do with the stock VC nipple leave it open or run it into the can has well.
It is gonna have a filter on top and drain it manually, the car will be about 650hp-700 tops on c16..
Old Nov 28, 2007 | 04:26 PM
Lmgrcivic's Avatar
Default Re: best way to setup custom breather kit?? (Samuels)
just put a filter on it
Old Nov 28, 2007 | 04:39 PM
Samuels's Avatar
Default Re: best way to setup custom breather kit?? (Lmgrcivic)
put a filter on what? the vc nipple?
I just wanna know the best way to set it up..
I was thinking about just doing 2 off of the block instead of the 1 and 2 off of the VC and running the VC nipple all into to the catchcan..
Rasmusm
Feb 2, 2013 12:42 PM
tegman23
May 27, 2009 09:51 AM
SurferDude905
May 26, 2009 07:23 PM
tekstyle
11
Jan 8, 2008 12:23 PM
a1320addict
Jan 14, 2007 08:04 AM
