WILL 14s fit on a GSR
Old Nov 28, 2007 | 01:05 PM
da9blk1's Avatar
Default WILL 14s fit on a GSR
NEED ANSWER FAST!
arnt blades 14? or they 15s?
GRAF-FITI's Avatar
* B A N N E D *
Default Re: WILL 14s fit on a GSR (da9blk1)
blades are 15's
14's will fit fine
/thread
Old Nov 28, 2007 | 01:06 PM
da9blk1's Avatar
Default Re: WILL 14s fit on a GSR (GRAF-FITI)
agreed??? ?
Old Nov 28, 2007 | 01:07 PM
GRAF-FITI's Avatar
* B A N N E D *
AGREED
Old Nov 28, 2007 | 01:10 PM
St Jimmy's Avatar
* B A N N E D *
14's will fit.
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: WILL 14s fit on a GSR (St Jimmy)
Yes ...
Old Nov 28, 2007 | 01:20 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: WILL 14s fit on a GSR (Byaaah!)
I got a set of 185/65-14 winter tires on 14" steelies from the Tire Rack, and they fit fine on the '94 GS-R. BTDT.
Old Nov 28, 2007 | 01:43 PM
acuradriva's Avatar
Default Re: WILL 14s fit on a GSR (nsxtasy)
94-01 integras come with 14's except for the gsr and itr. so yea they will fit. blades are 15" btw
Old Nov 28, 2007 | 01:44 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: WILL 14s fit on a GSR (acuradriva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuradriva &raquo;</TD></TR><TR><TD CLASS="quote">blades are 15" btw</TD></TR></TABLE>
dude i already said that
Old Nov 28, 2007 | 01:49 PM
posHonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuradriva &raquo;</TD></TR><TR><TD CLASS="quote">94-01 integras come with 14's except for the gsr and itr. so yea they will fit. blades are 15" btw</TD></TR></TABLE>
Not necessarily. LS mesh are 15s
Simply knowing the diameter of the wheel wont always tell us if the wheel will fit or not. Example, civic HX rims are 14s but with no modification they will rub on the gsr calipers.
Old Nov 28, 2007 | 03:39 PM
all-mtr-teg's Avatar
Default Re: WILL 14s fit on a GSR (posHonda)
[QUOTE=posHonda]
Not necessarily. LS mesh are 15s QUOTE
LS mesh also came on 97 gsr
Old Nov 28, 2007 | 03:40 PM
PACT man's Avatar
Yea, just because LS/GS/RS have 14" wheels doesn't mean that they fit the same on GSR/Type-R being as the front brakes are bigger(reason why the HX's don't fit unless you shave the caliper bracket).
Old Nov 28, 2007 | 03:43 PM
freakasis's Avatar
so the answer is.....some 14's will and some wont...you gotta try it out....
and i dont know of any 13's that will.
Old Nov 28, 2007 | 06:25 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: WILL 14s fit on a GSR (PACT man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PACT man &raquo;</TD></TR><TR><TD CLASS="quote">Yea, just because LS/GS/RS have 14" wheels doesn't mean that they fit the same on GSR/Type-R being as the front brakes are bigger(reason why the HX's don't fit unless you shave the caliper bracket).</TD></TR></TABLE>
Only the ITR has larger brakes. The GSR shares the same brakes as a GS, LS, and RS: 262 mm rotors in the front. GSR will work with 14" steelies. ITR requires 15" wheels because of the 282mm front rotors.
The HX wheels need to be modified for any non-ITR Integra.
Old Nov 28, 2007 | 06:43 PM
itsblue's Avatar
14's will fit not Problem, I run 14 steels in the winter. Also some 13's will fit I ran 13 x8.5 panasports at an autocross this fall...though they may not fit unless the brakes are moderately worn, they were very close to the caliper. Hope this helps
racingfan
14
Jan 11, 2008 08:11 PM
three stars, two bars
Oct 3, 2006 05:31 PM
teggsr925
Honda Fit
Apr 24, 2006 06:06 PM
Project_ED8
Oct 2, 2004 07:29 PM
fangtl
Nov 7, 2002 02:39 PM
