CFK sensor
No Results Found
Your search for cfk sensor returned no results.
Please try different search criteria or a different data set.
I'm doing a 96 spec JDM ITR swap into my gsr shell and I'm using a obd2a LS engine harness and there is a extra plug hanging which is for the CFK sensor. I need to know if the 96 spec JDM ITR motor has a CFK sensor and where its located. I looked all around the oil pan and didn't find a plug unless i wasn't looking hard enough.
This is what the plug looks like in case anyone is interested.
the crank sensor is located on the alternator side of the motor
i do not believe that JDM 96 spec motor came with this sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">Here is how you bypass ithttp://technet.ff-squad.com/ckftrick.htm</TD></TR></TABLE>
yep...i did this. works just fine
