missed gear, jumped time, fixed timing...feeling a little slow???
Old Nov 28, 2007 | 08:02 AM
h2b_sedan's Avatar
Default missed gear, jumped time, fixed timing...feeling a little slow???
well i got the timing straight and took it out and it just doest feel right. did a compression test. 195-200 aLL the way across. when its cold it idles weak some times like its bogging down to around 500 rpms. then if i rev it a little it will idle fine then come down again. possible to have a bent valve with good compression??
Old Nov 28, 2007 | 10:10 AM
h2b_sedan's Avatar
Default Re: missed gear, jumped time, fixed timing...feeling a little slow??? (h2b_sedan)
ttt
Old Nov 29, 2007 | 01:46 AM
h2b_sedan's Avatar
morning bump
Old Nov 29, 2007 | 01:49 AM
Duane_in_Japan's Avatar
A leakdown test is more exacting of what is going on inside the cylinder unless you have a friend with a vacuum transducer and an oscilloscope and he knows how to read vacuum waveforms. He may be able to pick something up on a plain ole secondary spark pattern.
Old Nov 29, 2007 | 07:39 AM
h2b_sedan's Avatar
Default Re: missed gear, jumped time, fixed timing...feeling a little slow??? (Duane_in_Japan)
okay i'll give it the ol' leak downer. thanks
Old Dec 3, 2007 | 01:37 AM
h2b_sedan's Avatar
bump. doin a leakdown later today!!
Old Dec 4, 2007 | 01:33 AM
h2b_sedan's Avatar
how do i keep the motor from turning over when doing the leak down??? pullbar on the crankshaft bolt??? also it threw a code for tps last night. could that be my problem???
Old Dec 5, 2007 | 03:59 AM
h2b_sedan's Avatar
ttt
Old Dec 5, 2007 | 09:15 AM
dbiker207's Avatar
to keep the motor from turning you have to get the piston your testing at top dead center. once you get the piston in the right place it will stay still on its own for the test.
xvietxkhmerxboix
Mar 3, 2006 03:05 PM
hondaeg8
22
Jan 6, 2005 07:37 AM
hondaeg8
13
Dec 23, 2004 09:05 AM
98lude
Jul 27, 2001 07:29 PM
quikrpm'z
Jul 6, 2001 06:29 AM
