88 CRX starting issues
Old Nov 28, 2007 | 06:42 AM
ArtyG's Avatar
Default 88 CRX starting issues - d16z6 obd1 swap
Read this thread not too far down before I posted this: https://honda-tech.com/zerothread/2160598
I am having the same issues, and did not wish to thread-jack. Forgot to add, OBD1 d16z6 swap/OBD0 injectors w/ resistor box.
Sitting in traffic, car just died. Friend said he tapped the area near the ECU/wiring under the dash. Car would not start back up. Car turns over, just no fuel and no spark.
Tested for spark and got no spark. Swapped dizzy's and again got no spark.
Checked the spark plugs and smelled no fuel before swapping dizzy's. Can't hear the fuel pump "whine" or "kick-on" when key turned to on position.
Thought it was the main relay - upon turning the ignition, no clicking. Tried a different working main relay, same issue. We are getting power to the main relay.
Took my OBD1 ECU and put it in my friends SOHC EG hatch, and his car cranked right up.
Battery is charged.
Any ideas? Suggestions? Comments?
Old Nov 28, 2007 | 08:33 AM
Harlowe's Avatar
Function>Fashion
Sounds like my problem, except I never had mine started in the first place .
and my battery is dead, so I have to swap my other car's in there whenever i work on it.
Have you checked your grounds?
And possibly the fuel pump main relay. Hoping that's just my problem
Old Nov 28, 2007 | 09:51 AM
ArtyG's Avatar
Default Re: (Harlowe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harlowe &raquo;</TD></TR><TR><TD CLASS="quote">Have you checked your grounds?</TD></TR></TABLE>Yeah, the three on the coolant/thermo neck, and then two on the motor. Can't forget the main one from the battery to the body, as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harlowe &raquo;</TD></TR><TR><TD CLASS="quote">And possibly the fuel pump main relay. Hoping that's just my problem </TD></TR></TABLE>Yeah, even tried another known working one...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArtyG &raquo;</TD></TR><TR><TD CLASS="quote">Thought it was the main relay - upon turning the ignition, no clicking. Tried a different working main relay, same issue. We are getting power to the main relay.</TD></TR></TABLE>
Old Nov 28, 2007 | 10:32 AM
ArtyG's Avatar
Default Re: (ArtyG)
Not sure if I mentioned it, but all fuses under-hood check out. None blown/popped.
Old Nov 28, 2007 | 12:52 PM
YLWCRX's Avatar
Default Re: (ArtyG)
My CRX did something similar. It would start but then would shut off, right away, as soon as the key turned from start to run. It turned out to be the ignition switch.
Old Nov 29, 2007 | 09:00 AM
ArtyG's Avatar
Default Re: 88 CRX starting issues - d16z6 obd1 swap (ArtyG)
Alternator fuse was blown. When the conversion harness was touched, it shorted something out. Also double-checked the connection to the under-dash fuse box and that was not 100%. Fixed that up...new fuse...and back in business.
That was a new one for me.
OkayTrash
Dec 30, 2011 09:11 AM
a1320honda
Nov 26, 2009 07:46 PM
mugeneghatchie
May 15, 2008 12:48 PM
Rob!
Feb 16, 2004 01:01 PM
wu tang
Jul 30, 2003 01:30 PM
