S2000 CEL FIX KIT?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melsun_ap1 »</TD></TR><TR><TD CLASS="quote">does anyone know where i can get this and how im supposed to install it? for my test pipe that shows a check engine light</TD></TR></TABLE>
hahahahaha.
you're looking for a o2 anti-fouler. not a "fix kit".
its so easy to install, even a caveman..uh....you can do it
hahahahaha.
Munkyw3rkz.webs.com
this installation will remove CEL (check engine light) that is caused when you install a test pipe (no cat) or high flow cat.
when this light comes on from your install of a new exhaust , be aware that this has no effect on the performance of your car. its just a stupid reminder that the o2 (oxygen) sensor is finding a problem caused when you removed or did something to the stock catalytic converter.
notes before starting
- you might have space for only 1 spark plug anti-fouler, sometimes using 1 will work / sometimes not
- having an electric drill helps out tremendously , those battery operated ones dont have that much power; they will still work but will be a pain
- this may still not solve your problem of the light; a small amount of people that try this 'quick fix' still cant get the light to go off
STEP 1
-purchase 2 spark plug anti foulers at your local auto parts store
-18 mm size
-made by HELP brand / part number 42002
-HELP has also another part number 42009 and are shorter in length than the 42002, i have heard they worked , but i am not 100 percent
STEP 2
-disconnect the negative terminal on your battery. this will reset your ecu
-take one of the anti foulers and drill out its center using a 1/2 bit ,
-this will increase its hole size and allow your stock o2 sensor to fit
STEP 3
-screw the drilled spark plug anti-fouler on top of the original
-be sure to use some kind of anti-seize on the treads. in case you need to remove your fix with ease
STEP 4
-unscrew your stock o2 sensor and place your cel / ses fix in
-use anti seize on the threads
-clean your cell (by wiping it off with a paper towel)
STEP 5
-reinstall your o2 sensor
STEP 6
-reconnect your battery (your ecu is reset)
-you have just solved the problem of the 'damn light keeps coming on'
ps. its cost me 8 dollars for the pack of 2 spark plug anti-foulers
STEP 1
-18 mm size
STEP 2
STEP 3
STEP 4
STEP 5
STEP 6
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K »</TD></TR><TR><TD CLASS="quote">haha s@ntos do you have that saved in like a word doc that you post everytime the question comes up?</TD></TR></TABLE>
no everytime i have to dig it up... LOL i bang my head on the desk when i saw it this morning and was like do i really wanna post it???
which is why i started the how to /DYI...
vtec_racer_2kgsr
Sep 20, 2002 05:09 PM
ActiveAero
Jul 30, 2001 07:31 PM
Jason
Jul 19, 2001 04:42 PM
