Honda S2000 Honda S2000
S2000 CEL FIX KIT?
Old Nov 27, 2007 | 08:40 PM
melsun_ap1's Avatar
Default S2000 CEL FIX KIT?
does anyone know where i can get this and how im supposed to install it? for my test pipe that shows a check engine light
Old Nov 27, 2007 | 08:56 PM
LAS2K's Avatar
Default Re: S2000 CEL FIX KIT? (melsun_ap1)
the big ol red search button his this topic covered by many people
Old Nov 27, 2007 | 09:01 PM
Techno Tonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melsun_ap1 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know where i can get this and how im supposed to install it? for my test pipe that shows a check engine light</TD></TR></TABLE>
hahahahaha.
you're looking for a o2 anti-fouler. not a "fix kit".
its so easy to install, even a caveman..uh....you can do it
Old Nov 28, 2007 | 08:20 AM
SlammedDC2teg's Avatar
Default Re: S2000 CEL FIX KIT? (Techno Tonis)
http://www.kingmotorsports.com/
Scroll to the bottom.
Old Nov 28, 2007 | 08:37 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: S2000 CEL FIX KIT? (SlammedDC2teg)
this installation will remove CEL (check engine light) that is caused when you install a test pipe (no cat) or high flow cat.
when this light comes on from your install of a new exhaust , be aware that this has no effect on the performance of your car. its just a stupid reminder that the o2 (oxygen) sensor is finding a problem caused when you removed or did something to the stock catalytic converter.
notes before starting
- you might have space for only 1 spark plug anti-fouler, sometimes using 1 will work / sometimes not
- having an electric drill helps out tremendously , those battery operated ones dont have that much power; they will still work but will be a pain
- this may still not solve your problem of the light; a small amount of people that try this 'quick fix' still cant get the light to go off
STEP 1
-purchase 2 spark plug anti foulers at your local auto parts store
-18 mm size
-made by HELP brand / part number 42002
-HELP has also another part number 42009 and are shorter in length than the 42002, i have heard they worked , but i am not 100 percent
STEP 2
-disconnect the negative terminal on your battery. this will reset your ecu
-take one of the anti foulers and drill out its center using a 1/2 bit ,
-this will increase its hole size and allow your stock o2 sensor to fit
STEP 3
-screw the drilled spark plug anti-fouler on top of the original
-be sure to use some kind of anti-seize on the treads. in case you need to remove your fix with ease
STEP 4
-unscrew your stock o2 sensor and place your cel / ses fix in
-use anti seize on the threads
-clean your cell (by wiping it off with a paper towel)
STEP 5
-reinstall your o2 sensor
STEP 6
-reconnect your battery (your ecu is reset)
-you have just solved the problem of the 'damn light keeps coming on'
ps. its cost me 8 dollars for the pack of 2 spark plug anti-foulers
Old Nov 28, 2007 | 10:02 AM
ReddotsS2K's Avatar
Default Re: S2000 CEL FIX KIT? (S@nt0s)
haha s@ntos do you have that saved in like a word doc that you post everytime the question comes up?
Old Nov 28, 2007 | 10:37 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: S2000 CEL FIX KIT? (ReddotsS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K &raquo;</TD></TR><TR><TD CLASS="quote">haha s@ntos do you have that saved in like a word doc that you post everytime the question comes up?</TD></TR></TABLE>
no everytime i have to dig it up... LOL i bang my head on the desk when i saw it this morning and was like do i really wanna post it???
which is why i started the how to /DYI...
S@nt0s
Honda S2000
22
May 16, 2009 08:47 AM
JDMsocalcivic
22
Feb 4, 2006 07:54 AM
vtec_racer_2kgsr
Sep 20, 2002 05:09 PM
ActiveAero
Jul 30, 2001 07:31 PM
Jason
Jul 19, 2001 04:42 PM
