auto trans shifting wierd
Old Nov 27, 2007 | 05:28 PM
eurowned's Avatar
Default auto trans shifting wierd
As the title states, i'm having trouble in my new teg....
I noticed this yesterday but i thought it was because i was very low on gas. Today it happened a couple times, i will have my foot on the pedal and it will not go any faster it stays at the same speed until it finally does shift it's notchy. The check engine light went on today, but it goes off the next time i start my car.
What does this sound like to you guys? I don't know much at all about tegs let along mechanics.
Help me out!!!
Old Nov 27, 2007 | 05:31 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: auto trans shifting wierd (eurowned)
Pull the stored CEL. The Integra FAQ thread stickied at the top has an instruction link with the codes.
Old Nov 27, 2007 | 05:40 PM
eurowned's Avatar
Default Re: auto trans shifting wierd (Dogginator)
never mind i just saw how to do it.
Modified by eurowned at 10:19 PM 11/27/2007
Old Nov 27, 2007 | 05:43 PM
Dogginator's Avatar
Daisy... Daisy...
Get a paper clip and follow this link:
https://honda-tech.com/zerothread?id=978933
Old Nov 28, 2007 | 03:52 AM
eurowned's Avatar
Does the check engine light have to be on for this to work?
because i tryed and nothing
Old Nov 28, 2007 | 03:57 AM
Dogginator's Avatar
Daisy... Daisy...
No, the codes should be stored. If you are having trouble, the other option is to go to a local auto parts store and have them pull the codes with a reader. They should do this for free.
Old Nov 28, 2007 | 04:13 AM
eurowned's Avatar
I read how to do it, do i use the paper clip to connect the two wires while the car is running, then turn it to ING position?
Old Nov 28, 2007 | 04:17 AM
Dogginator's Avatar
Daisy... Daisy...
You insert the paper clip with the car off. You then switch the ignition to the run position to display the codes. They car should not be running.
mcorley187
13
Apr 26, 2013 06:44 AM
tedj1957
Nov 29, 2009 08:02 AM
dc2long
Oct 21, 2006 04:46 PM
01GSRteggie
Jun 29, 2006 09:48 AM
Spoolin'VW
15
Nov 19, 2005 03:27 PM
