Suspension & Brakes Theory, alignment, spring rates....
Sway Bar connectors
Old Nov 27, 2007 | 03:30 PM
needtoknow's Avatar
Default Sway Bar connectors
I have a 1997 crv and want to know if I change one sway bar connector on one side do I have to do the other side at the same time? Thx
Old Nov 27, 2007 | 03:39 PM
bmoua's Avatar
Default Re: Sway Bar connectors (needtoknow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by needtoknow &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1997 crv and want to know if I change one sway bar connector on one side do I have to do the other side at the same time? Thx</TD></TR></TABLE>
which connectors are you talking about? the endlinks?
Old Nov 27, 2007 | 05:04 PM
needtoknow's Avatar
Default Re: Sway Bar connectors (bmoua)
yes I am
Old Nov 27, 2007 | 05:33 PM
Tyson's Avatar
shouldnt matter
why is it you have to replace it anyway? howd it break?
Old Nov 27, 2007 | 06:18 PM
Targa250R's Avatar
be professional
Default Re: Sway Bar connectors (Tyson)
You don't need to replace both at the same time, but you should inspect the opposite side for play while you're under there. Also check out the bushings, and the front sway bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">shouldnt matter
why is it you have to replace it anyway? howd it break?</TD></TR></TABLE>
'97-01 CR-V sway bar endlinks are pretty notorious for developing play, which causes a pretty noticeable rattling noise. We replace a lot of the balljoint-type sway bar links for this reason.
team_exceed
Apr 11, 2008 08:08 AM
brian_98EK
Sep 8, 2007 12:22 PM
kornerk12
Jan 15, 2007 04:09 PM
igo4bmx
Suspension & Brakes
Mar 19, 2006 10:15 AM
JMD
Apr 13, 2003 07:30 PM
