WTF code 4 crank angle sensor with new dizzy HELP PLEASE
Old Nov 27, 2007 | 03:20 PM
crxfreak1117's Avatar
Default WTF code 4 crank angle sensor with new dizzy HELP PLEASE
ok im throwing code 4 which is crank angle sensor.. so i read i had to replace the dizzy in order to fix it so just bought a new distirbutor from advanced put in it and still code 4 and still cant rev past 3500rpms?
the car is a 89 crx dx with headlight to taillight 88 hf wiring harness
b16 turbo converted to obd1 using the jumper harness and a crome ecu? i also tried my extra p30 and still same thing what is my problem
and before anyone posts this i did reset my ecu.....
Old Nov 27, 2007 | 04:15 PM
ludesrv's Avatar
Old wiring harness snap wires inside the harness.
Check the continuity from the ECU pin out to the dizzy. If it's good then check it to the body ground. It's 2 wires for that sensor, gonna take you 15 minutes to eliminate a probable problem. I had to replace my TDC wire when I had my old hatch. I just ran a new wire, from the sensor to the plug, the from the plug to the ecu.
Old Nov 27, 2007 | 07:39 PM
alscrx's Avatar
Default Re: (ludesrv)
Prop not the sensor but the circuit.
Check your contacts!
Old Nov 27, 2007 | 10:31 PM
1 Fly SI's Avatar
Default Re: (alscrx)
Did you clear the codes?
Old Nov 28, 2007 | 05:56 AM
Default Re: (1 Fly SI)
thanks for everyones help i just fixed it... it was the 2 wires from the dizzy to the ecu just ran 2 new wires and fixed the problem
1 fly si; please read the post before u respond i did reset my ecu and it still happened but fixed now thanks again
b00stFED
36
Jan 15, 2015 09:01 AM
crxsi814
Jan 22, 2011 04:28 PM
panda_eh2
Nov 11, 2009 12:01 AM
SpoonEk253
Nov 8, 2006 08:12 PM
lilgreenman
Jun 17, 2003 04:40 PM
