Help...radio won't power on but there's power to the radio (2000 Civic)
I have a 2000 Civic LX. It had an after market radio and I'm attempting to reinstall the factory Honda radio. I have power to the radio however, two different factory Honda radios will not power up.
No enter a code message etc. The 10 amp fuse is fine and I'm getting power to the large blue factory socket which plugs directly into the radio (test light confirms this.) Any ideas????
Not sure if it has "Constant" power. How can I verify? I wasn't aware that there is an under the hood fuse. Is this located in the relay/fuse box?
Do you know which pin or color of wire on the wiring harness is the constant power source?
Will use a multimeter
idumpwitmy12gaugepump
Audio / Security / Video
May 22, 2008 07:18 PM
