92 acura integra help (how far should it be)
Old Nov 27, 2007 | 12:19 PM
politepilljocky's Avatar
Default 92 acura integra help (how far should it be)
how many inches does your engine valve cover to feder have to be cause i just swap in a B20 into my da, i want do know this because my axel keeps breaking on the driver side i bought and autozone axel they told me on g2ic.com that the autozone axel came 1 inch shorter so aim trying to see if its true cause aim trying to figure out if its my axel thats short or if i did not put the engine in the right way?i dont want to buy another axel if its not that u know what i mean
any one on this website that has a da would help alot in see how many inches is yours?
pic to help out what iam talking about
Old Nov 27, 2007 | 03:35 PM
stumpy21's Avatar
Default Re: 92 acura integra help (politepilljocky)
i'm not sure what the distance is supposed to be but i can tell you from personal experience that the autozone axles are really a hit or miss thing. sometimes you get good ones sometimes you get crap that starts clicking the moment you put them on. on a side note there are two other things that should be considered, how low you are and your engine mounts. hope this is of some help to you
Old Nov 27, 2007 | 05:51 PM
Default Re: 92 acura integra help (stumpy21)
i just want to know the lenght from the motor to the fender on a stock da whit a stock motor, how many inches ?
Old Nov 27, 2007 | 05:55 PM
ls19integra95's Avatar
im not sure how many inches but it also could be that autozone axle... buddy had a da that he did a b16 swap into after he spun a bearing and a 2 month old autozone axle snapped and then broke and bent a lot of other parts...
Old Nov 28, 2007 | 10:07 AM
Default Re: 92 acura integra help (ls19integra95)
just need the distance help!
Old Nov 28, 2007 | 10:37 AM
asr10 user's Avatar
dont do it
Old Nov 28, 2007 | 10:54 AM
SuckMyDOHC's Avatar
the axles shouldn't have **** to do with "valve cover to fender" length. The motor is sitting on its mounts which means the location is preset. Maybe you should just buy your axles from somewhere else if they keep snaping
Old Nov 28, 2007 | 11:41 AM
RaceCarRyne's Avatar
Default Re: (SuckMyDOHC)
make sure that you get the corect axle too.
Old Nov 28, 2007 | 12:06 PM
.PLUMMM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC &raquo;</TD></TR><TR><TD CLASS="quote">the axles shouldn't have **** to do with "valve cover to fender" length. The motor is sitting on its mounts which means the location is preset. Maybe you should just buy your axles from somewhere else if they keep snaping</TD></TR></TABLE>
x2. That distance really shouldnt play a role in your axle length. If the motor was runing and working, I highly doubt it was a swapping issue. Just buy your axles from somewhere else. I have heard the good and the bad about autozone axles
nuber1zero
Sep 16, 2013 12:39 AM
integrada9
Sep 20, 2008 10:01 PM
sixtodc2
Sep 29, 2007 08:06 PM
racereaper7
May 5, 2006 08:53 PM
h4x
Sep 13, 2004 01:21 AM
