Slip Fit joints
Old Nov 27, 2007 | 09:42 AM
hybrid2007's Avatar
Default Slip Fit joints
Are there other ways to expand pipe for slip fit joints other than using an expander?
I was thinking about making a die and seeing if i could press it into one end of the pipe which would expand it and then pressing it out again, i geuss i would have to this before i cut the piping to form the collector.
What do you think?
Old Nov 27, 2007 | 09:54 AM
beepy's Avatar
Default Re: Slip Fit joints (hybrid2007)
Pipe expanders are not very expensive. Why bother making something that won't work as well, and still pay the cost of materials?
Old Nov 27, 2007 | 10:09 AM
hybrid2007's Avatar
Materials would be free, and to be honest i think the end product would come out a bit nicer than using something like this:
http://www.harborfreight.com/c...37354
Old Nov 27, 2007 | 03:39 PM
kyle3838's Avatar
i bought a pipe expander from harbor freight and it broke pretty quick
Old Nov 27, 2007 | 04:39 PM
2kjettaguy's Avatar
Default Re: (kyle3838)
Harbor Freight pipe expanders aren't worth their weight in pennies.
Old Nov 28, 2007 | 10:29 AM
hybrid2007's Avatar
Default Re: (2kjettaguy)
Thats what i thought
Is doesnt seem worth spending out on one that will do the job for the 6 joints i need to do.
Do you think it would work if i turned down a piece of round bar to the OD of the pipe im using and then pressed it in?
Old Nov 28, 2007 | 12:39 PM
Bakeoff's Avatar
If you only need a couple pipes done, what about driving to an exhaust shop and slipping the guy 10 bucks to do it?
Old Nov 28, 2007 | 12:48 PM
hybrid2007's Avatar
Default Re: (Bakeoff)
Thats deffinately an option, but if i can do all the work myself i would like to.
Old Nov 28, 2007 | 01:36 PM
nowtype's Avatar
Default Re: (hybrid2007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid2007 &raquo;</TD></TR><TR><TD CLASS="quote">Thats deffinately an option, but if i can do all the work myself i would like to.</TD></TR></TABLE>
Not an option. The tools that do slip fit exhausts are quite expensive. I remember DanielM3(mazzuri bend guy) bought one and it was $500+ and still had issues with doing 16 gauge SS.
The cost effective and easiest way to do things is go to a muffler shop or buy the expanded pieces from pepboys/autozone.
Old Nov 29, 2007 | 10:52 AM
hybrid2007's Avatar
Default Re: (nowtype)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">
The cost effective and easiest way to do things is go to a muffler shop or buy the expanded pieces from pepboys/autozone.</TD></TR></TABLE>
I dont quite see your point? You have just told me that its not an option to go to an exhaust shop and then recomended that i go to an exhaust shop.......
There is a muffler shop close to me that would do it for me but as said before i would like to do it myself
Old Nov 29, 2007 | 11:05 AM
nowtype's Avatar
Doing it yourself and being cost effective is not an option. Go find a machine that does the job. Find out how much it will cost. Then figure out how many times you would have to use it to make it worth while. I bet going to the local muffler shop and spending $5 a joint will be the best option.
Old Nov 29, 2007 | 12:16 PM
hybrid2007's Avatar
Dude i've not mentioned once that i'm going to go out and spend mega money on an expander. The only expander i have referred to is a $20 one from harbour freight?
I am talking about machining a bit of stainless to make a die that i can press into pipe to expand it which will form my slip fit joint.
Old Dec 1, 2007 | 11:30 AM
welfarepc's Avatar
take one of those metal wedge doo dads from an old school tire machine or wheel balancer and hammer that **** muncher into your exhaust. done!
adambomb93
May 6, 2015 04:01 AM
85
Feb 17, 2010 09:35 AM
r0yal
Welding / Fabrication
Apr 19, 2006 07:03 PM
AlxSiR7
Jun 20, 2005 06:37 PM
EGJDM
Jan 9, 2005 09:02 AM
