Open header= too rich to keep running?
I have a open header and it is just until I can ride to go get exhaust....I just did a motor swap (LS) and I can not get it to keep running...I just think its running too rich because of the lack of exhaust, am I right?
BTW I have tried a chipped p28, p05, and a LS ECU with no luck
EDIT: it is a Hytech replica header
No.
I went from a stock tiny Y7 manifold with built in cat to a open big tube SMSP and it ran fine. Once you get the exhaust on it you'll notice the change in power. After you get your mystery problem fixed.
I worked on a open header ZC circle track car this summer and it ran fine.
Are any of the ECU's you used throwing CEL codes? If your check engine light is on I would get the code(s) fixed.
no codes but it was a automatic...and I took out the cams and put manual cams in (slightly larger) and didn't adjust the vavle lash...so I now have the auto cams in and am going to retime it tomorrow (or thursday
DelsolioGSR1996
31
Sep 27, 2006 05:40 PM
