dark and light areas after paint
Old Nov 26, 2007 | 09:50 PM
matmcg's Avatar
Default dark and light areas after paint
I havnt done a clear coat yet but their are some dark spots that throw off the paint is there anyway i can sand them down to match the other parts or anything i can do ??
they are most likely from the end of each spray
Old Nov 27, 2007 | 09:03 AM
matmcg's Avatar
bump
Old Nov 27, 2007 | 10:29 AM
snowseeker's Avatar
Default Re: (matmcg)
Did you prime the whole car or just parts? How many coats of base did you do? Clear should be shot no more than an hour after base is shot.
Old Nov 27, 2007 | 06:59 PM
Team Rukus's Avatar
Default Re: dark and light areas after paint (matmcg)
if your seeing light and dark spots that means you painted it wrong. either you didnt prime the entire car and did only EVEN coats all over the car OR you did not apply cover coats on the spots that were fixed first and then do an overall coat on the car. the way it sits right now the only thing you can do (cheapest solution) is to get some more paint on it and have it look unified (the area's where its light get more paint on it) once it reaches the colour as the dark panels then do a complete shot all over the car to balance it out.
the proper way to doing it and making sure you get the best paintjob ever you need to apply a paint sealer before the base coat so it covers everything first.
crazyhouse2011
Paint and Body
Oct 21, 2014 10:27 PM
masijdm
Paint and Body
Feb 24, 2009 11:09 AM
Sic_DA_Nine
Paint and Body
Mar 3, 2008 10:38 AM
goofball123321
Jul 1, 2003 02:50 PM
type_racerz
11
Dec 25, 2002 02:19 PM
