ITR head.. does this look normal to you?
Old Nov 26, 2007 | 07:23 PM
Fat Chick Magnet's Avatar
Default ITR head.. does this look normal to you?
96' spec ITR.. pretty dirty, but do those scratches on the wall look normal to you and the rocker arm wear? I think this is the first time in history this motor had its valve cover taken off. pretty yucky in there.
Old Nov 26, 2007 | 07:56 PM
BlueR's Avatar
Default Re: ITR head.. does this look normal to you? (Fat Chick Magnet)
the scratches/rough finish on the walls are normal...part of the unfinished casting process
as for the rocker arm, its hard to tell...
is there any reason for you to suspect abnormal wear on the rockers?
is everything in there stock?
Old Nov 26, 2007 | 08:10 PM
Default Re: ITR head.. does this look normal to you? (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">the scratches/rough finish on the walls are normal...part of the unfinished casting process
is everything in there stock?</TD></TR></TABLE>
yes everything is bone stock i just purchased this motor from a warehouse and decided to take valve cover off like i always do when i buy a new motor.
Gunns's Avatar
I second the scratches being normal. My 98 spec looks the same.
Old Nov 26, 2007 | 08:12 PM
i messed around with the contrast of the picture a little i hope this helps.
Old Nov 26, 2007 | 09:30 PM
Cheeze's Avatar
Default Re: (Fat Chick Magnet)
Looks fine to me..It has some meat left on it so at least you know its not metal to metal.
Old Nov 26, 2007 | 10:10 PM
tartje's Avatar
Default Re: (Cheeze)
thats normal rocker wear
and the scratch marks are normal too
Old Nov 26, 2007 | 10:13 PM
Default Re: (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">thats normal rocker wear
and the scratch marks are normal too</TD></TR></TABLE>
thanks i feel more confident about the motor now
Old Nov 27, 2007 | 05:21 AM
cmdr430's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cheeze &raquo;</TD></TR><TR><TD CLASS="quote">Looks fine to me..It has some meat left on it so at least you know its not metal to metal.</TD></TR></TABLE>
uhh....meat?
what else would it be besides metal to metal?
the oil that makes its way to the head lubricates the rocker arms...but if there is no oil it is metal to metal.....
OP looks normal to me
Old Nov 27, 2007 | 05:46 AM
fourcsan's Avatar
* B A N N E D *
you know... like brake pads, JASMA brake pads?
Old Nov 27, 2007 | 05:47 AM
fourcsan's Avatar
* B A N N E D *
looks straight to me. i have seen MUCH dirtier. clean it up if you plan on rocking coverless at shows. i always clean mine when i got it off
Old Nov 27, 2007 | 12:24 PM
finally dropped her in today looking forward starting her up tomorrow.
Fat Chick Magnet
13
Nov 29, 2007 09:37 AM
EK_vzla
Honda Motorcycles
Apr 10, 2005 01:43 PM
Takumi Fujiwara
Apr 8, 2005 09:13 PM
b19coupe
Sep 1, 2004 11:48 AM
WCI
Jun 7, 2003 12:51 PM
