ITR head.. does this look normal to you?
Old Nov 26, 2007 | 07:16 PM
Fat Chick Magnet's Avatar
Default ITR head.. does this look normal to you?
96' spec ITR head.. pretty dirty, but do those scratches on the wall look normal to you and the rocker arm wear? I think this is the first time in history this motor had its valve cover taken off. pretty yucky in there.
Old Nov 26, 2007 | 07:29 PM
onepoint6i's Avatar
Default Re: ITR head.. does this look normal to you? (Fat Chick Magnet)
looks pretty normal to me..well from what i can tell from the quality of those pics..
Old Nov 26, 2007 | 07:31 PM
Default Re: ITR head.. does this look normal to you? (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">looks pretty normal to me..well from what i can tell from the quality of those pics..</TD></TR></TABLE>
yeah my dad has my camera i was using my phone. there is a little sludge on the cam plate you think its a good idea to clean it with a little brake part cleaner then drain out my oil and change it?
Old Nov 26, 2007 | 07:35 PM
onepoint6i's Avatar
try using sea foam inside the engine..i heard it works wonders..i've never personally used it...
i would think brake cleaner would clean it ok, but i wouldnt trust brake cleaner going inside my crank case... or any part of my bearings cam or crank etc...
Combustion Contraption's Avatar
The 'scratch' marks are normal. Hard to see rocker arm wear with &lt; 1/2 of the arm exposed.
Old Nov 26, 2007 | 07:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">try using sea foam inside the engine..i heard it works wonders..i've never personally used it...
i would think brake cleaner would clean it ok, but i wouldnt trust brake cleaner going inside my crank case... or any part of my bearings cam or crank etc...</TD></TR></TABLE>
too late i cleaned it a little with brake part cleaner, but yeah im going to try some of that sea foam.
Old Nov 26, 2007 | 07:56 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Chick Magnet &raquo;</TD></TR><TR><TD CLASS="quote">too late i cleaned it a little with brake part cleaner, but yeah im going to try some of that sea foam.</TD></TR></TABLE>
haha..youre doing while you lurk on H-T
Old Nov 26, 2007 | 08:13 PM
haha..youre doing while you lurk on H-T </TD></TR></TABLE>
yah man i love lap tops.
I'm putting on the new valve cover gasket set as we post on HT.
This motor pulled 230-235 across the board on a dry test. Is that good for a JDM itr motor? If its not i could always return the motor and pick out another one from the batch. Hopefully it just doesn't blow smoke out the tail pipe i know ITR's have a habit of burning oil.
Old Nov 26, 2007 | 08:17 PM
onepoint6i's Avatar
yeah those numbers look good ....i highly doubt it'll burn oil..but you never know
Old Nov 26, 2007 | 08:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">yeah those numbers look good ....i highly doubt it'll burn oil..but you never know </TD></TR></TABLE>
let it burn oil.. true ITR motor.
but let it not blow out smoke and block peoples view behind me when i hit vtec.
Old Nov 26, 2007 | 09:55 PM
prettylew's Avatar
brake cleaner eats rubber. so if you cleaned your head with it say bye to your valve seals! and congrats you now burn oil! lol good job
Old Nov 26, 2007 | 09:57 PM
Default Re: (prettylew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prettylew &raquo;</TD></TR><TR><TD CLASS="quote">brake cleaner eats rubber. so if you cleaned your head with it say bye to your valve seals! and congrats you now burn oil! lol good job</TD></TR></TABLE>
its okay theres new valve seals and valvetrain going in next month along with cams. and i didnt spray inside the head i sprayed it on a paper towel and wiped the cam plates .
Old Nov 27, 2007 | 12:25 PM
finally dropped in the *****!
Old Nov 29, 2007 | 09:37 AM
onepoint6i's Avatar
Default Re: (Fat Chick Magnet)
dope
Fat Chick Magnet
Nov 27, 2007 12:24 PM
Esdelota
25
Oct 28, 2006 11:58 AM
b19coupe
Sep 1, 2004 11:48 AM
Simple
26
May 3, 2004 08:20 PM
WCI
Jun 7, 2003 12:51 PM
