Is it safe to take off the ABS reservoir?
Take it off and what?
If you plan to remove it completely, you will need to run the Integra RS hardlines and 40/40 prop valve.
If you plan to remove it temporarily, you will need to bleed your brake lines once you reinstall it.
But you just cant take if off...you wont have brakes!
Oh damn! Like totaly no brakes at all? Or just the anti lock brakes? My ABS isnt working so im just planning to take that thing off.
your brake fluid goes through the ABS bank so when you push the pedal all of your fluid will come out and you wont have ANY brakes at all!!!! dont take it out unless you are going to run the RS brakes
