toda springs with spec A's or not with stock (been seaching for days)
Old Nov 26, 2007 | 05:43 PM
ricekiller1's Avatar
Default toda springs with spec A's or not with stock (been seaching for days)
im wondering if its is worth swappin out the itr valvetrain for toda springs when putting in toda A's..do the A's make enough power up top to rev past the stock redline with a just a mugen HG to bump the compression on an otherwise stock ITR motor(IHE)????? thanks guys
Old Nov 26, 2007 | 05:47 PM
BlueR's Avatar
Default Re: toda springs with spec A's or not with stock (ricekiller1)
how old are your stock valvesprings and retainers?
i would swap them out since the toda As are a bit more agressive
and you don't need to go with toda valvesprings, there are plenty of good alternatives for a lot less money
Old Nov 26, 2007 | 05:56 PM
Racebrewer's Avatar
Default Re: toda springs with spec A's or not with stock (BlueR)
Hey,
ITR springs work with everything up to and including 12 MM. I have a JUN II intake with stock springs. If you aren't exceeding 12MM lift or raising the RPM range, stock R springs work just fine.
If they are real old get new ones.
Unless needed, stiffer springs merely increase wear and tear without benefits.
John
Old Nov 26, 2007 | 06:05 PM
Default Re: toda springs with spec A's or not with stock (Racebrewer)
the spring only have about 30k on them but im thinkin i might want to to more aggresive cams in the future. and i was thinking the toda springs might be overkill for the a's. maybe even robbing power from the engine??? am i completely wrong? also if i get spring will the stock retainers be fine?
BlueR's Avatar
NEW stock retainers all the way
Old Nov 26, 2007 | 06:11 PM
over skunks or BC? they are like 50$ more??
Old Nov 26, 2007 | 06:12 PM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricekiller1 &raquo;</TD></TR><TR><TD CLASS="quote">over skunks or BC? they are like 50$ more??</TD></TR></TABLE>
if you are referring to ti retainers, they wear down too fast for daily driving
Old Nov 26, 2007 | 06:14 PM
great info...is there any reason to rev the a's over stock redline??? do they make power that high?
Old Nov 26, 2007 | 06:37 PM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricekiller1 &raquo;</TD></TR><TR><TD CLASS="quote">great info...is there any reason to rev the a's over stock redline??? do they make power that high?
only correct way to determine that is to get on the dyno
Modified by BlueR at 10:57 PM 11/26/2007
Old Nov 26, 2007 | 06:56 PM
i was waiting for that resonse...thanks for the help!!! the ITR section is Da'BoMB!!!!
Old Nov 26, 2007 | 07:19 PM
BlueR's Avatar
glad we could help
Old Nov 26, 2007 | 07:21 PM
hypeR_ash's Avatar
too LEGIT to quit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">glad we could help</TD></TR></TABLE>
and by we he means he
Old Nov 26, 2007 | 07:25 PM
BlueR's Avatar
Default Re: toda springs with spec A's or not with stock (hypeR_ash)
&lt;-------------------
a modest fellow
Old Nov 26, 2007 | 07:38 PM
GO-FIGHT-KILL's Avatar
^ Whose snores are almost as loud as his caR.
Old Nov 26, 2007 | 07:45 PM
BlueR's Avatar
Default Re: (GO-FIGHT-KILL)
thats was gat!!!!!!!!!
Old Nov 26, 2007 | 07:49 PM
Todd00's Avatar
I said I don't want a title!
As people have said, Toda A's will work fine with the OEM ITR valvetrain. Back in the day they were made off of CTR blanks...or so the story goes.
Not sure if the new ones are or not, but I kept my 'vintage' set of Spec A's just because it is such a great cam. Who knows, I might put them in someday, lol.
Old Nov 27, 2007 | 03:20 PM
Default Re: toda springs with spec A's or not with stock (Todd00)
but are the springs too stiff for those cams and going to harm rockers or the cams after a while? i will be daily drivin this car...????im trying to decide if this is a stupid question or not?????
Old Nov 27, 2007 | 04:16 PM
B18CXr's Avatar
with a stock head, nope
Old Nov 27, 2007 | 04:58 PM
Default Re: toda springs with spec A's or not with stock (B18CXr)
what about with the toda spings, blueprint ploished intake manifold with portmatch 70mm throttle body? mugen HG?
Old Nov 27, 2007 | 05:07 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricekiller1 &raquo;</TD></TR><TR><TD CLASS="quote">great info...is there any reason to rev the a's over stock redline??? do they make power that high?</TD></TR></TABLE>
My brother's ITR with Toda A's didn't make maximum power until around 8500 or 8600 RPM. Fuel cut is set at 8900, if I recall correctly. Peak was ~192 whp.
Head is stock, with the exception of a Mugen gasket.
Old Dec 3, 2007 | 07:11 PM
Default Re: toda springs with spec A's or not with stock (Padawan)
^^^what other mods did he have with his setup to make 192??
Old Dec 3, 2007 | 07:23 PM
Padawan's Avatar
Darth ModerVader
- Toda A's
- SMSP header
- Car Sound 2.5" cat
- 2.5" exhaust
- AEM CAI
- Mugen 2-layer headgasket
- Prelude 290 cc injectors
- B&M FPR
- PS removed
- Chipped P72 ECU
- Tuned by Jeff Evans using Uberdata
ricekiller1
Nov 27, 2007 11:25 PM
ricekiller1
Nov 27, 2007 03:18 PM
Mr.Integra
Dec 4, 2002 10:31 PM
nsx-Animal
Jul 2, 2001 02:42 PM
