K24a3/K20Z3 ?
My cousin has his own tuner shop, where he prefers to work on VWs but keeps busy and makes money with Hondas. He claims you can take the bottom end from the K24a3 (accord) and slap a K20z3 head on it and you will have an engine putting out 250hp/250tq. I'm not sure if he meant itd have those numbers without any work, because it was in the middle of thanksgiving dinner and everyone was talking. But is there any truth to this? He says the K20z3 head flows a lot better. I believe this is possible since the K24a3 is obviously de-tuned for fuel efficiency. Are these numbers correct? Anyone tried this?
hes gonna get me in trouble...one day, my mom is gonna come out to her car ('05 accord ex) and find it on jack stands, with the motor out of it, lol
I know that the new Frankenstein is an RSX-S head on an Accord or Element block, but I don't know about the new k20z3 head, just hte k20a2. Oil passages may be different or some such.
I'd look at k20a.org, they always seemed to have a WEALTH of info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sciowninyou »</TD></TR><TR><TD CLASS="quote">Is it still relatively safe though? The rsx-s head is higher comp...?</TD></TR></TABLE>
a2 head is 9.8:1 compression. z3 head is 11.0:1, so the si actually has higher a compression ratio.
You should really search around on k20a.org, they probably have a LOT more experience than anyone on here, because we just got our cars and they're still all in one piece for hte most part
The heads all bolt up but you need to do something with the head gasket for the coolant and oil channels to line up correctly and The K24 block is like 6 or 8 millimeters taller also because of the longer stroke of the block. But swapping blocks is pointless right now because we dont have any really good tuning options yet. So you wouldnt get the full pontential out of it for the money and time spent doing this. If you just did the normal i/h/e/r with a lighter flywheel and some pully's you would probably see better gains than the swap.
found ALOT of info on k20a.org
this has had interested me for a while as well... slap a k-pro + turbo to the frankenstein equation and its starts to make a whole lot of hp sense.
without further adieu.. here is the info i have found thus far.
__________________________________________________ ____________________
Lots of K-Frank info from kevinoneill
K24a2 meets Type S Oil Pump w/pics(no 56k) from Suprfast
K24 Frank build up link from Compdoc777
The Definitive K20/24 Sensor Comparison. from Froth
This is a lil list I made from Chameleon's build thread
Stuff that doesn't work:
K24A4 Pistons
Needed:
K24 Block (type dosen't matter, K24A2 (TSX) has oil squirters)
K24 Timing Chain + Guides
K24 Water pump
K24 Timing cover
K24 Headgasket
K24A2/A1 rods and pistons
CRV Timing mount
K20A2 Head
K20A2 Crank baffle
K20A2 Alternator
K20A2 Thermo housing
K20A2 Starter
K20A2 Oil pan, pump and chain (pump needs to be modified for the K24A4 oil pan)
NOTES:
K20A2 oil pump on K24-
Quote:
Originally Posted by edo
Something to be mindful of, if you're not already aware:
The accord block will not accept the K20A(2) oil pump directly. The girdle has a raised ridge or hump right down the middle. The CRV K24A1 block does not have this ridge.
So, either you retain the accord block's oil pump/balance shaft assembly, or you can notch the K20A(2) oil pump so that it will clear the raised ridge and then bolt down onto the accord girdle. Other oil feed/return holes will need to be plugged as well on the accord girdle if adapting the K20A(2) oil pump.
-Ron
Quote:
Originally Posted by carl
The K series buries the balance shafts in the oil pan and it requires a fair amount of power to run those "propellors" in oil (not to mention the nice froth you get). They also spin at 2X the crank RPM vs. 1.7 for the RSX or S2K pump. The faster the pump rotors spin, the harder for them to fill and not cavitate.
Quote:
Originally Posted by spowers
It is not bolt on. You have to modify #1 main cap/pump assy to fit it, in addition to removing the oil orifice (and plug the hole that isn't tapped on all version of the K) that feeds the balancer bearings on main #3. You also need the PCX oil pump chain and for 100% correctness the PNC chain guide, as the larger sprocket diameter on the rsx pump used with the longer PNA guide puts a bit too much angle on the chain. Many overlook this. There are a couple pieces of hardware that are different too.
If you use the K24 block, all of them use counterbalanced oil pump (AS DOES THE 06 SI). It is better to replace this heavy pump by the k20a2 oil pump that didn't use balancer. If you do that, don't forget to plug the secondary oil line on the k24 block that is to lubricate the bearing of the k24 pump. In the pic, #16 (pn 90004-PE2-005) and #21 (pn 90401-PE2-003) are the factory bolt and lock washer that will do this. These are from the Type-S, and they are recommended if you are using a K20 oil pump and/or oil pan.
ill find more little tidbits of info and add them here accordingly
K24A4 Pistons
Needed:
K24 Water pump
K24 Timing cover
K24 Headgasket
CRV Timing mount
K20A2 Head
K20A2 Crank baffle
K20A2 Alternator
K20A2 Starter
NOTES:
-Ron
and yet another write up:
http://www.sportcompactcarweb...._head/
What and why
There's no substitute for displacement, except maybe technology, so in a perfect world you'd have both. If you're driving a Honda powered by the new K-series engine, there's a relatively easy way to get both. Take the big 2.4-liter block from an Element, CR-V, or Accord and mate it with the high-flow head from the K20A2 found in the RSX Type-S. It's almost that easy. Almost. This swap can be called a head swap or a block swap, depending on what you start out with and what you want to achieve. It can also be dubbed a "poor man's TSX engine." Regardless, you'll wind up with the intake and exhaust side VTEC system on top of a 2.4-liter block, and as we'll see, the marriage works.
There's VTEC, and then there's VTEC
Honda has used two very different VTEC systems on K-series engines. In spite of the engine's differences, both happen to be called i-VTEC. The first system, found on the K20A2 (RSX Type-S) and K24A2 (TSX) has three cam lobes for each pair of valves. At low rpm, each valve follows its own mild cam lobe. At high rpm, they both start following the third lobe, which has higher lift and more duration for better high-speed cylinder filling. This is the VTEC you're used to. The second system, found on the K24 (Element, CR-V, Accord) and the K20A3 (base RSX and Civic Si), is designed to minimize emissions and maximize driveability and gas mileage. In this system, there are two cam lobes, a normal one and a puny little atrophied one, for each pair of intake valves (nothing happens on the exhaust side). At light load and low rpm, each lobe opens one valve, so most of the intake air goes through the valve that's opened more. This creates a swirl in the combustion chamber that happens to be great for combustion efficiency. Floor it, though, and one valve won't be enough, so both valves follow the bigger lobe. Notice there's no screaming high-rpm race lobe here.
The "i" part of i-VTEC stands for VTC (don't ask us how they came up with that) the Variable Timing Control system that graces all of the K-series engines, whether they have the go-fast VTEC or the sissy model. VTC simply advances or retards the entire intake cam.
The block
K24 blocks are ready to make big horsepower numbers. The crank and rods are similar in construction to the K20A2 parts, but with beefier rods, bigger rod bearings and additional counterweights on the crank. The K20A3 engine, sourced from the base RSX and Civic Si, is built for less power and lower rpm. Honda got the extra 400cc for the K24 from both an increase in bore from 86mm to 87mm and an increase in stroke from 86mm to 99mm. The additional stroke forced a 19.7mm increase in deck height, which might only become apparent when you let the hood drop, so check those hood clearances carefully. Remember, this also means your exhaust manifold will move up 19.7mm, so make sure you have that kind of room, or prepare to make adjustments. Sales figures for the 2002-and-up CR-V, Accord and Element are already nearing a half-million, so you shouldn't need to stay glued to eBay for a chance for one. Expect to pay between $650 and $1,000 for a complete K24 engine in good condition. The K24A1 that sits in the CR-V has a 9.6:1 compression ratio, while the K24A4 found in the Element and Accord have 9.7:1. The other differences between the K24 applications, most notably the presence of EGR, used on the Accord and the Element, and a variable length intake runner system, found on the CR-V, are irrelevant since we're not using the K24 head.
Although we haven't seen any yet, it's possible Honda will come out with ultra-efficient K24s for tighter emissions standards. Keep a watchful eye out for these as they may be trimmed down (bad) for lower friction and weight. Also beware of pre-2002 CR-Vs, which had a B-series variant. You can also find the K24A2 in the TSX, and it's different enough to need its own paragraph. The TSX mill is a mixed blessing. With a 10.5:1 compression ratio and a 7100-rpm redline, it makes 200 hp (179 hp at the wheels on our dyno). To cope with the higher revs, it has stronger rods and a unique crank. It also happens to have basically the same head we're swapping on here. Sounds great, so why not just transplant the complete TSX engine? One, it's rare and expensive. Two, it comes with throttle-by-wire and an ECU that's not compatible with other K-series-powered vehicles. To make the TSX engine more "swappable," install an RSX Type-S or Civic Si intake manifold and throttle body on it. You'll have to engineer a block-off plate or plug for the EGR port on the TSX head, since it will be exposed with the new intake manifold. So the big question is: Should you buy a TSX engine if you have the chance? If you intend to stick with natural aspiration or light boost, it would be a good choice with its high compression. Additionally, the only other part you'd need to find is a short runner intake manifold. The choice boils down to what you want to do with the engine and what parts you already have.
The head
The RSX Type-S is the only North American source for the K20A2 cylinder head, so you might have to widen your search to find one in the United States. JDM engines are a good alternative. In this case, the engines we're interested in are called K20A and are found in Civic Type-Rs and Integras. They're typically shipped with a transmission (which has a limited-slip diff) and an ECU, all costing between $3,500 and $5,500. The K20A engines are trick, stuffed with pistons that will squeeze an 11.5:1 compression ratio. The cylinder head you'll wind up with is arguably better as well, utilizing longer duration intake and exhaust cams and dual valve springs on both the intake and exhaust sides, no doubt to cope with 8600-rpm blasts. Don't get the K20A2 or K20A confused with the K20A3, which is the base-model RSX engine that you'll be disappointed with if it shows up at your doorstep.
If at all possible, start with two complete engines. You'll miss out on a few important parts if you buy a K24 short block like the timing chain and timing chain cover, unique to the tall-deck K24. The same goes for the K20A2. They're nothing that a costly trip to the parts counter won't fix, but just be aware before you jump at the first K24 block that you see holding the door open at your favorite junkyard.
Mix 'n' match
Let's start at the bottom. Either of the oil pans will work, but the RSX Type-S part is cast aluminum vs. the K24's stamped-steel part. The cast pan is stiffer and braces the pan to the transmission bell housing, making it the better choice. You should also use the full-length windage tray from the K20A2, which will do a better job keeping the oil where it needs to be. The K24 uses a pair of balance shafts cleverly incorporated into the oil pump assembly ("pump holder set" in Honda-speak), but you don't need their extra weight or the friction required to turn them. Hasport recommends ditching the K24 oil pump assembly in favor of the simpler K20A2 part. The oil pump drive chain and tensioners are identical, so take your pick, or get a new one if in doubt about its condition.
You can avoid the machine shop if you don't want the oil-to-water oil cooler that's used on the K20A2. An oil cooler of some kind, however, is a good idea; at least, Honda thought it was on the RSX Type-S. The stock unit has the advantage of being able to warm the oil in cold weather. To plumb the stocker, have the K24 block machined for the coolant return line, which is right above the oil filter boss on the K20A2. Any decent machine shop can do this. You'll also need to use the K20A2 water pump since it has the coolant supply fitting for the oil cooler. Although the factory system serves its purpose, you could do just as well with a sandwich-type oil filter adaptor and a decent air/oil cooler.
On the front of the engine, the K24 timing chain, tensioner, guide and timing chain cover will be used due to the taller deck height. The K20A2 crank pulley is smaller than the K24's to keep the accessory rpm down on the higher-revving engine. Think of it as a free underdrive pulley. On top, use the K24 head gasket, which is sized for the 1mm-larger bore diameter. The head can be bolted on with either set of head bolts; they're identical.
Engine assembly
Start by stripping both engines to short blocks. There's no need to touch any of the rod or main bolts unless new pistons or a rebuild requires it. With a few exceptions, we're tucking a K24 block between all the good parts of the K20A2. As always, arm yourself with a factory service manual for assembly procedures and torque specs. Every thread in the motor is tapped in aluminum, an unforgiving material to a tyrant with a breaker bar. Begin assembly with the bottom end. Install the K20A2 pump holder set on the K24 block. Top it off with the K20A2 oil pump and oil pump drive chain. Next, install the water pump housing, using the K20A2 part if you want to retain the factory oil cooler. Hondabond is used on this joint to make the seal.
Install the K24 cylinder head gasket and lay the new cylinder head in place. It's your choice to reuse the head bolts or the gasket, but again if you're in doubt, or if you have plans for forced induction, buy new parts. Note the head bolt torquing procedure is different between used and new head bolts. Consult the manual for details. Once the head is torqued down, you can install the casting that holds the rockers, followed by the cams and the cam bearing caps. Install the K24 timing chain, tensioner and guide and replace the crank angle sensor wheel, making sure to put it on in the right direction. Cover it all up with the K24 timing chain cover (and more Hondabond to keep the oil in).
Both Hasport and its friends at Hondata have found that K-series engines heat their intake air significantly, causing issues with engine management and power output. Hondata now sells a heatshield intake manifold/cylinder head gasket to replace the factory part. It has measured intake manifold surface temperatures from 15 to 45 degrees Fahrenheit lower than stock with this gasket. If you're going to try one, it will never be easier than right now. Because of the extra deck height, the K20A2 intake manifold support bracket that stretches to the block won't quite reach. We fabricated a 19.7mm tall aluminum spacer to take up the slack. On the cheap without a lathe, you can do something similar with a stack of washers. Don't worry, we won't tell.
All of the bits that still need to go on are straight off of the K20A2, another good reason to avoid the cheap K20A2 cylinder head being used as a jackstand for your friends' del Sol. The one exception is the K24 dipstick, which is longer to reach down the taller block into the pan. Surprisingly, the stock RSX Type-S ECU will make the new K24 run well enough for grocery runs, but hard driving would be unwise. The ECU bases fuel delivery on rpm, manifold pressure, and the amount of air that it knows a K20A2 ingests under those conditions. Since it doesn't know about that extra stroke, it won't add the fuel to go with it. The timing is also optimized for 11.5:1 compression, and can now be advanced significantly for the low 9.5:1 or 9.7:1. Conveniently, Hondata offers a modified ECU the way we like 'em, plug-and-play. Just like on the Sci-Fi channel, your brain will get modified and shipped back with a USB connector on the back, along with some software that will let you tune the Honda ECU yourself. It'll also supply an assortment of base fuel and spark maps to get you started. No extra wiring, no extra sensors, no stress headaches. Well, until you start tuning it.
Free power
Sometimes we run across a mod that's so easy and effective, we wonder what kind of cost-management weenie would nix the idea. This is one of them. If they'd shipped the RSX Type-S with our hybrid, it would've been a fierce competitor, even against the turbocharged clan (beat by a Dodge...ouch). Our 2.4-liter mustered 30 lb-ft more torque across the rev range, leading to a power increase between 15 and 30 hp all the way from 2000 rpm to redline. Is this free power? Basically. The added displacement is good for more than a 25-percent increase in torque throughout the rev range, with no loss of driveability. The hybrid can even drink the cheap gas, thanks to the lower compression ratio. True, you can't impress yourself with an 8000-rpm redline, but that's a small price to pay for going faster. Using the K24 block not only adds torque, but the hybrid's lazy 9.6:1 compression ratio cries out for supernatural aspiration. And remember, it doesn't take much boost to make insane power with 2.4 liters. We like this mod because you get great results from stock parts. Especially if you already have an RSX Type-S or anything else with a K20A2 stuffed into it, you'll be hard pressed to find another bolt-on that nets as much power for the price. So the adage is correct; there is no replacement for displacement. We've just combined it with a dose of modern engineering to prove it once and for all.
i want a k20/24 frank
What and why
The block
The head
Mix 'n' match
Engine assembly
Free power
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MessGSR »</TD></TR><TR><TD CLASS="quote">use a tsx bottom end stronger and higher comp</TD></TR></TABLE>
um... wouldn't you just use the whole TSX motor? It already has what's basically the z3 head.
good info in this thread though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY »</TD></TR><TR><TD CLASS="quote">
yeah, the article states that people aren't doing that because of the price of the motor and the tuning options dbw etc. (like you said in the other post dunno what year the dbw started on the txs)
</TD></TR></TABLE>yeah, the article states that people aren't doing that because of the price of the motor and the tuning options dbw etc. (like you said in the other post dunno what year the dbw started on the txs)
yeah, I was really just responding to the guy who said use the TSX short block instead of the accord short block. If you can find a TSX block, it probably still has the head attatched ya know?
I do understand the lack of available TSX motors though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FG2quick »</TD></TR><TR><TD CLASS="quote">a2 head is 9.8:1 compression. z3 head is 11.0:1, so the si actually has higher a compression ratio.
Are you sure its because of combustion chamber design and not The pistons used?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soxfan143 »</TD></TR><TR><TD CLASS="quote">But swapping blocks is pointless right now because we dont have any really good tuning options yet.
Tuned with the Greddy emanage ultimate can see some respectable numbers. The only thing that the emanage ultimate can't do is tune cam angles, and that where most of the real power is at.
Regardless you would have more power over stock.
You might see more peak power produced, but adding 400 cc's of displacement and changing the rod ratio creates a more linear power band that is more usable.[/</TD></TR></TABLE>
A CRV K24 block, race header, tuned with Emanage ultimate net a gain of 207 peak horse power but saw 25-40 HP gains over stock on the high cam.
It can be seen here http://www.8thcivic.com/forums...61319
The torque gains were not shown but we all know what a LSVTEC does for torque and Im sure the same could be applied.
Remaining stock < performaing block swap
Imagine adding the plethora of parts people ad to get 200WHP and an A2/Z3 2.4 block could do.
Or the new K24Z3 found in the 2008 EX Accord $1376.92 at hondapartsdeals.com
https://www.hondapartsdeals.co...+2010
Modified by Kidnkorner at 1:52 PM 11/30/2007
</TD></TR></TABLE>Are you sure its because of combustion chamber design and not The pistons used?
Tapen00n
Oct 8, 2004 04:52 PM
