home made shift light
Old Nov 26, 2007 | 05:27 PM
northemt88's Avatar
Default home made shift light
I have a ex cluster in my 91 civic hatch. I was wondering if theres any way to hook up a shift light (little led) to the cluster. Any ideas would be great. Thanks
Old Nov 26, 2007 | 09:26 PM
layedoutat0psi's Avatar
bump for wonderin the same thing except i got a stock cluster
Old Nov 27, 2007 | 06:27 AM
ridgeapd's Avatar
Rig it so that your CEL bulb comes on at the shift point... or maybe the "Crusie Control" light. sleeper.
Old Nov 27, 2007 | 06:42 AM
89efDUSTY's Avatar
Default Re: home made shift light (northemt88)
LOL @ this thread, OP you will need an RPM activation switch, you can basically make anything happen with it at a desired RPM, such as enable a light, solenoid, clicker, etc.
Old Nov 27, 2007 | 06:43 AM
Ermil's Avatar
Default Re: home made shift light (89efDUSTY)
You have to stop and ask yourself, does my car warrant a shift light? If not, you will look like a tool. (See Fred Durst)
Old Nov 27, 2007 | 06:47 AM
89efDUSTY's Avatar
Default Re: home made shift light (Ermil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil &raquo;</TD></TR><TR><TD CLASS="quote">You have to stop and ask yourself, does my car warrant a shift light? If not, you will look like a tool. (See Fred Durst)</TD></TR></TABLE> HAHAHAHA unless he wants the fuel economy? But I highly doubt that is the case.
Old Nov 27, 2007 | 07:47 AM
Gearspeed-Performance's Avatar
Rig it to your horn or windshield wipers...
Old Nov 27, 2007 | 03:59 PM
ludesrv's Avatar
I had an electrical engineer look at this for me. I was gonna attach it to super bright LEDs (ebay has them cheap) and then hid the LED into my vents so my vents light up when it was the shift linkage. The super brights (colored if you chose) can be seen in the middle of the day they are that bright.
Reading the tach wire (signal from dizzy, it's the blue wire on the dizzy) signal, a wave signal, 2 per RPM, can be read and have a program that had a signal to the LED when the RPM I set it at was hit. I was gonna get it programmed and wired for different colored led, orange when I was 1000rpm away from my limit, then red at my limit.
Lazyness took over and I haven't gotten the program done. Oh well.
Old Nov 27, 2007 | 05:29 PM
BILLETGRIP's Avatar
Default Re: (ludesrv)
seems like 2 rpm activated switches would be alot simplier or maybe a 2-step
Old Nov 27, 2007 | 06:12 PM
one of my buddys has a 93 hatch thats got a turboed h22a in it and his check engine light lights up when its time to shift
Old Nov 27, 2007 | 06:51 PM
BILLETGRIP's Avatar
Default Re: (layedoutat0psi)
how does he know when its throwing a code? or is it throwing a code when its time to shift?
Old Nov 27, 2007 | 07:31 PM
grey_ghost's Avatar
Default Re: (BILLETGRIP)
LMFAO...^^^^...i was wondering the same thing
Old Nov 27, 2007 | 08:09 PM
northemt88's Avatar
so how would you do that
rivoe302er
Feb 13, 2007 08:29 AM
EK79
May 21, 2006 01:19 PM
slayersluck
Mar 7, 2005 04:28 PM
sleeperb
Nov 5, 2002 04:01 PM
Cyrio
Feb 27, 2002 10:53 PM
