h22a integra is slow
Old Nov 26, 2007 | 05:10 PM
b0yJeEnYuS's Avatar
Default h22a integra is slow
i bought a 90 integra with a h22a in it and im looking for a few extra ponies. i want to stay na, what would be the cheapest way to go? need to save money for wheels and suspension... any advice would be appreciated. thanks
Old Nov 26, 2007 | 07:41 PM
GSR in progress 96's Avatar
* B A N N E D *
Default Re: h22a integra is slow (b0yJeEnYuS)
Get some cams
Old Nov 26, 2007 | 08:30 PM
Turbo-GSR1287's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b0yJeEnYuS &raquo;</TD></TR><TR><TD CLASS="quote">h22a integra is slow. </TD></TR></TABLE>
Does this statement surprise you? Boost FTW!
Old Nov 26, 2007 | 08:34 PM
envision's Avatar
Default Re: h22a integra is slow (Turbo-GSR1287)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-GSR1287 &raquo;</TD></TR><TR><TD CLASS="quote">
Does this statement surprise you? Boost FTW! </TD></TR></TABLE>
x2
Old Nov 26, 2007 | 11:42 PM
matmcg's Avatar
gut the car and you will see a difference , its slow because of the added engine weight , make the car lighter and you will see a big difference that engine has plenty of torque
Old Nov 27, 2007 | 12:31 AM
Doostur's Avatar
https://honda-tech.com/zeroforum/44
I say boost
Old Nov 27, 2007 | 05:38 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: (Doostur)
Boost x4...
But if you do want to stay N/A go for some cams...
Old Nov 27, 2007 | 06:41 AM
forumnoobie's Avatar
"i want to stay na, what would be the cheapest way to go?"
Old Nov 27, 2007 | 06:47 AM
Byaaah!'s Avatar
Default Re: h22a integra is slow (forumnoobie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forumnoobie &raquo;</TD></TR><TR><TD CLASS="quote">
Unfortunately neither is...
But you should go for bolt-ons then...
Old Nov 27, 2007 | 07:54 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b0yJeEnYuS &raquo;</TD></TR><TR><TD CLASS="quote">i bought a 90 integra with a h22a in it and im looking for a few extra ponies. i want to stay na, what would be the cheapest way to go? need to save money for wheels and suspension... any advice would be appreciated. thanks </TD></TR></TABLE>
1st thing you should do is have the car tuned and make sure it's running correctly.
My $500 H22 longblock went 12.6's on stock internals NA in my DC2
Old Nov 27, 2007 | 09:39 AM
inostageh23's Avatar
boost ftw, squeeze for the blow
Old Nov 27, 2007 | 11:34 AM
vsmdc4teg's Avatar
If you search around you will find that a h22 is not much heavier than a b18. I think it was under 100lbs.
Old Nov 27, 2007 | 12:11 PM
nate_2k5's Avatar
Default Re: (vsmdc4teg)
going boost on that car when it already has the potential to be a NA powerplant is stupid, especially with the way the h22 reacts to it.
get good boltons, then work on the head, you should be able to run 13's in that car with minimal work
Old Nov 27, 2007 | 06:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsmdc4teg &raquo;</TD></TR><TR><TD CLASS="quote">If you search around you will find that a h22 is not much heavier than a b18. I think it was under 100lbs. </TD></TR></TABLE>
Im pretty sure its only a difference of about 40 lbs between the b18 and h22
Old Nov 27, 2007 | 06:45 PM
ls19integra95's Avatar
Default Re: (Turbo-GSR1287)
a buddy mine had an h22 in his civic and was quick as hell and slamed you in your seat with, cams, intake, full exhaust header back, clutch, flywheel, plugs, wires, dizzy, intake manifold and throttle body you dont have to do much to those engines and you will have a fast car...
Old Nov 27, 2007 | 07:43 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
headwork, boltons and a tune./
Old Nov 27, 2007 | 07:46 PM
posHonda's Avatar
Im pretty sure its only a difference of about 40 lbs between the b18 and h22</TD></TR></TABLE>
Yea theres only about 40-50lbs of difference between a b18 and a h22.
If you have an integra than I see absolutely no reason to not go h2b as you most likely already have most of the B series parts. The h2b will cost about the same as the full h22 swap if you already have the B series crap and itll be much much quicker. Slap in the b16 tranny
Old Nov 27, 2007 | 11:07 PM
Pat_S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zeroforum/44
I say boost </TD></TR></TABLE>
What he said.
Old Nov 28, 2007 | 03:24 AM
adamrich33's Avatar
Default Re: (Pat_S)
its a no for cams and gutting your car, if you install cams correctly along with rebulding the valvetrain, your gonna be close to spending what a turbo kit cost.
Old Nov 28, 2007 | 05:16 AM
Default Re: (adamrich33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamrich33 &raquo;</TD></TR><TR><TD CLASS="quote">its a no for cams and gutting your car, if you install cams correctly along with rebulding the valvetrain, your gonna be close to spending what a turbo kit cost.</TD></TR></TABLE>
My thoughts exactly
Old Nov 28, 2007 | 07:08 AM
Schister66's Avatar
Man U FTW
If you MUST stay NA, you're faced with a decision. Either pay up and get some power or muddle around with I/H/E (and waste $1000) for a few extra horsepower...emphasis on FEW. If you want to have a fun, reliable, faster car, then boost it. I boosted my GSR and couldnt go back to an NA Honda (other than an NSX)
Old Nov 28, 2007 | 10:29 AM
asr10 user's Avatar
sell the car
Old Nov 28, 2007 | 10:36 AM
Schister66's Avatar
Man U FTW
Default Re: (asr10 user)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asr10 user &raquo;</TD></TR><TR><TD CLASS="quote">sell the car</TD></TR></TABLE>
Thanks for your amazing contribution
Old Nov 28, 2007 | 11:02 AM
asr10 user's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for your amazing contribution </TD></TR></TABLE>
Sorry, but if its slow, and you want to stay NA. Its going to stay slow. Sell the car if you want speed.
Old Nov 28, 2007 | 12:08 PM
.PLUMMM's Avatar
Its going to be pricey either way. As your well aware, you always pay more for H series parts! On the bright side, you will notice a difference if you add some Cams and/or Valvetrain. Id also throw in an Intake Manifold, considering Christmas is so close ; ] haha
