JDM fog light bulb question...
Old Nov 26, 2007 | 02:28 PM
saikou's Avatar
Default JDM fog light bulb question...
I had purchased a set of clear JDM fogs for my 4th gen and one of the bulbs ended up being burnt. I went ahead and ordered a set of new H3 bulbs, but unknowingly ordered 12V 80W specific bulbs... eBay
I think I needed 12V 55W specific bulbs. I'm going to guess it's not a very good idea to use the wrong wattage bulbs, am I correct? Should I go ahead and order the correct ones or would these bulbs work?
Old Nov 26, 2007 | 03:59 PM
mgags7's Avatar
They're just going to be brighter/hotter.
Make sure you have them wired up on their own power feed with a relay and all, if you put an extra 35w load on the parking light system you might blow fuses, that would be almost 3 more amps.
Old Nov 26, 2007 | 07:57 PM
saikou's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">They're just going to be brighter/hotter.
Make sure you have them wired up on their own power feed with a relay and all, if you put an extra 35w load on the parking light system you might blow fuses, that would be almost 3 more amps.</TD></TR></TABLE>
Thanks Matt,
I have them wired up just like factory, with the under-dash relay... just no fog light switch for now; paper clip. I'll most likely play it safe and use the correct bulb as recommended.
EVOTHIS
Sep 11, 2007 09:39 PM
turboITRDC$
Jul 10, 2007 08:22 PM
tca0bell
Apr 29, 2005 09:04 AM
Viorent Grip! EG
15
Jun 7, 2004 01:54 AM
MoJoJoJo
Jun 23, 2002 06:27 PM
