Gas tank shinanigans
Old Nov 26, 2007 | 12:19 PM
FFX's Avatar
FFX
Default Gas tank shinanigans
Hello, I just wanted an opinion and i also have a technical question.
I was filling my 2002 Honda Accord with fuel using a 1 gallon plastic container, when I pulled out the nossle, I noticed that the Plastic cap about 3/4ths of an inch in Diameter was no longer attached to the tip of the nossle. So the assumption I am making about this whole situation is now i have a little plastic cap that is flat floating in my gas tank.
Is this going to be a problem?...its 190 bucks to remove the fuel containter. I am assuming that the cap floats in the fuel, but I am not sure.
Also, I have heard that some cars have two fuel filters, one in the tank and one near the engine. Is this one of those situations?
Thanks for any reply. Appreciate the help!
Old Nov 26, 2007 | 12:57 PM
YeuEmMaiMai's Avatar
Default Re: Gas tank shinanigans (FFX)
no it won't be a problem but if you REALLY MUST get it there is an access panel in the trunk where you can remove the fuel pump and retreive it.
Old Nov 26, 2007 | 01:23 PM
FFX's Avatar
FFX
Default Re: Gas tank shinanigans (YeuEmMaiMai)
hey, thanks a lot. Appreciate your help. I may just retrieve it that way.
Old Nov 26, 2007 | 02:28 PM
use wooden and brass tools only since you DON'T WANT TO SET YOUR *** ON FIRE FROM A SPARK
Slade Exulis
10
Mar 16, 2016 08:14 AM
91cb7h23
Feb 10, 2013 04:13 PM
hybrid2007
Welding / Fabrication
12
Feb 19, 2009 03:13 PM
Layziebtnh055
10
Oct 27, 2004 12:38 PM
b18a1
Sep 3, 2001 05:02 PM
