crx cable to hydro conversion
Old Nov 26, 2007 | 09:04 AM
tomek5x's Avatar
Default crx cable to hydro conversion
i was wondering if its worth the money converting a crx to hydro? I got a b16 hydro tranny and im thinking of just trading it for a b16 cable
what u guys think??
thaaaanks
Old Nov 26, 2007 | 11:59 AM
EL Vap133's Avatar
Default Re: crx cable to hydro conversion (tomek5x)
You mean as opposed to using the Hasport cable to hydro conversion? I'd say stixk with the hydro tranny, most cable trannies grind gears and cable trannies are becoming scarce.
Old Nov 26, 2007 | 12:24 PM
gunnerman's Avatar
Default Re: crx cable to hydro conversion (EL Vap133)
I should have done the same and switched to a hydro as well...most cable trannies you run into are old and require a rebuild. You will need the conversion hundred something and new tranny mounts. When i researched it originally it came out to about 350 or so. It wasn't worth the extra money. But now i regret not going that route...
Old Nov 26, 2007 | 12:29 PM
turboZChatch's Avatar
Default Re: crx cable to hydro conversion (gunnerman)
convert to hydro for the reasons above (most cables tranny's are messed up) I converted after i put 3 different tranny's in my car and all were messed up....hydro b16 with quaife lsd FTW
Old Dec 21, 2007 | 09:33 PM
yonkers062986's Avatar
Default Re: crx cable to hydro conversion (turboZChatch)
ok so would we go about doing this coversion? And please something other than those kits from hasport and inovative.
Old Dec 22, 2007 | 09:32 AM
gunnerman's Avatar
Default Re: crx cable to hydro conversion (yonkers062986)
that's pretty much the only route to go....those mounts are well-engineered and the techs know what they're talking about. so i'd go hydro if i were you. I'm in the process of rebuilding my cable tranny. buying a cable tranny is hit and miss unless you really know the guy or drive the car with the tranny in it before you buy it.
eastbayg
Dec 6, 2008 08:14 AM
Slowboy!
Feb 25, 2006 08:49 AM
88civichbz6
Jan 29, 2005 06:07 PM
RI_TM
Jul 8, 2004 02:13 PM
