JDM DA6 Cluster
Old Nov 25, 2007 | 11:26 PM
Ricextacy's Avatar
Default JDM DA6 Cluster
If i install this will the RPM, Speed, gas, and temperature be Accurate?
Old Nov 26, 2007 | 12:11 AM
DC4 Dave's Avatar
Everything will be accurate, the only difference is the speedo, which reads in kilometers. You can even go so far as to open the clusters up, and swap just the speedometer part out, to get an MPH speedo in the JDM cluster, with the higher tach redline. You would essentially make it a GS-R cluster.
Old Nov 26, 2007 | 05:07 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (DC4 Dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4 Dave &raquo;</TD></TR><TR><TD CLASS="quote">Everything will be accurate, the only difference is the speedo, which reads in kilometers. You can even go so far as to open the clusters up, and swap just the speedometer part out, to get an MPH speedo in the JDM cluster, with the higher tach redline. You would essentially make it a GS-R cluster.</TD></TR></TABLE>
enough said with this quote, unless you like doing fly-by spedd calcs in your head like used to have to do
8bluddyknuklz
Jan 25, 2010 12:30 PM
2-7offsuit
15
Aug 13, 2005 10:43 AM
95dxhatch
28
Oct 8, 2004 08:28 AM
cloproductions
Sep 23, 2004 05:27 PM
giff74
Feb 1, 2004 04:20 AM
