Dyno test of Vibrant 4-2-1 2.5" collector header
Old Nov 25, 2007 | 10:33 PM
Team 4's Avatar
Default Dyno test of Vibrant 4-2-1 2.5" collector header
We recently installed this header on a customer's car in addition to the 2.5" header collector kit (test pipe), and tuned it a little bit further with an AFC Neo. I still can't believe the results.
The motor is an OBD2 B16A.
Mods include:
AEM short ram intake
Skunk 2 66mm TB
Skunk 2 IM
Vibrant 2.5" 4-2-1 header
2.5" test pipe
Skunk 2 catback
B&M FPR
AFC Neo
The results should speak for themselves.
Keep in mind the only things we changed were the header, the test pipe and a little more tuning.
This vehicle had been tuned before, but what a difference in power!
Vibrant makes a hell of a product.
Old Nov 25, 2007 | 11:39 PM
shiroitenshi's Avatar
Default Re: Dyno test of Vibrant 4-2-1 2.5" collector header (Team 4)
nice, typical returns for a B16A.
Old Nov 26, 2007 | 12:20 AM
Fat Chick Magnet's Avatar
nice, but you need a 2.0L bottom end now.
Old Nov 26, 2007 | 09:13 PM
Mike@K-Tuned's Avatar
Default Re: (Fat Chick Magnet)
I have seen very similar gains on numerous occasions from Vibrant's 4-1 version of this header. Nice budget header. Not the best, but pretty nice because it works.
Old Nov 27, 2007 | 06:18 AM
Rollo Lawson's Avatar
i've let off half a dozen of these units in the last few years and they make power. quality and ground clearance are excellent . i prefer these much more than their 4-1 piece
Old Nov 27, 2007 | 06:40 AM
Chillinit's Avatar
Default Re: (Rollo Lawson)
The best bang for the buck IMO. I achieved just over 200 whp on my B18c1 build using it...but then again, dyno numbers don't mean much.
Anyhow, in terms of craftsmanship, it scores high. Welds are good and ground clearance is superb. Can't go wrong.
Old Nov 27, 2007 | 07:27 AM
mar778c's Avatar
Community Builder
Community Influencer
nice results.
Old Nov 27, 2007 | 09:21 AM
Mohsin's Avatar
nice, where is vtec set? 5350ish?
Old Nov 28, 2007 | 10:13 AM
Team 4's Avatar
Default Re: (Mohsin)
I think we set it to 5500rpm if I recall correctly.
Old Nov 28, 2007 | 10:29 AM
MikeySpec's Avatar
Default Re: (Team 4)
Now try that Vibrant header on a high output B and see how your results are.
Old Nov 28, 2007 | 10:34 AM
gsrob's Avatar
Pretty nice gains there. I'm sure there will be much more with further modifications.
Old Nov 28, 2007 | 11:03 AM
Default Re: (MikeySpec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeySpec &raquo;</TD></TR><TR><TD CLASS="quote">Now try that Vibrant header on a high output B and see how your results are.</TD></TR></TABLE>
what do u consider high output? 2L, 12/1, stg.2 minumum cam? cuz chillinit made 204whp 136wtq with this same unit. 81.5mm, 87.2mm, BC4. thats pretty damn good for an off shelf header
Old Nov 28, 2007 | 12:19 PM
DA_JDM's Avatar
Default Re: (gsrob)
X2
Old Nov 28, 2007 | 12:20 PM
DA_JDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rollo Lawson &raquo;</TD></TR><TR><TD CLASS="quote">
what do u consider high output? 2L, 12/1, stg.2 minumum cam? cuz chillinit made 204whp 136wtq with this same unit. 81.5mm, 87.2mm, BC4. thats pretty damn good for an off shelf header</TD></TR></TABLE>
Imagine with an SMSP, Hytech, RMF header...it would probably jump a couple more WHP on that motor
Old Nov 28, 2007 | 01:29 PM
spcrxracer's Avatar
Default Re: (DA_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM &raquo;</TD></TR><TR><TD CLASS="quote">
Imagine with an SMSP, Hytech, RMF header...it would probably jump a couple more WHP on that motor </TD></TR></TABLE>
let's see someone dyno these and compare charts with the vibrant
Old Nov 28, 2007 | 01:46 PM
Team 4's Avatar
Default Re: (spcrxracer)
Guys, for $$$/hp, the Vibrant is tough to beat.
Old Nov 28, 2007 | 09:19 PM
MikeySpec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team 4 &raquo;</TD></TR><TR><TD CLASS="quote">Guys, for $$$/hp, the Vibrant is tough to beat.</TD></TR></TABLE>
Maybe about 4 years ago, but nowadays the fakie hytech units make greater power for less. The vibrant 4 into 1 has horrible clearance, does not do well on high output engines, and weighs a ton. I have to dig it up in my dynojet files but i have some comparisons on the vibrant vs. spark headers. On a 2.0L making 230+ whp, you wouldnt even think it was the same engine.
Rok_Stok
Oct 30, 2009 12:36 PM
HondaCivic2006
Honda Civic (2006 - 2015)
11
Oct 16, 2009 10:56 PM
BOMBAY
Sep 14, 2007 09:56 AM
SleepnCiViC
Nov 10, 2005 08:19 AM
