Just installed an ACT organic clutch, now problems!
Old Nov 25, 2007 | 08:44 PM
Teamdiesel's Avatar
Default Just installed an ACT organic clutch, now problems!
I just had an Organic Performance disk and heavy duty pressure plate from ACT installed two weeks ago and now I have issues. I went drag racing tonight and after about six races I noticed that I had to pres the clutch in much further to get engagement, but didn't pat much attention to it. When I put it in first, staged , and let her rip, the car didn't move . I put it in gear and gave gas and the thing acted like it was in neutral. I mean I put it in all the gears. let off the clutch, and the car wouldn't even die or sputter foward. I had to get it toed home. Please help me understand what went on.
Old Nov 25, 2007 | 09:06 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Just installed an ACT organic clutch, now problems! (Teamdiesel)
i had the same clutch and one day while driving my car jumped amd then felt like it was in nuetral no mater what gear it was in so i found out it was my pasenger side axle the teath were grinded away but i was hitting around 140 mph testing my speeds in 5th the night before so im sure its the same problem couse if the axle teath are grinded away the flywheel cant move the axle to make the wheels turn but i could be wrong.
Old Nov 25, 2007 | 09:30 PM
all-mtr-teg's Avatar
Default Re: Just installed an ACT organic clutch, now problems! (wunfstgsr)
Sounds like either your axle popped out, or like wunfstgsr mentioned, perhaps worn out splines on the axle.
Old Nov 25, 2007 | 09:38 PM
SP GARAGE's Avatar
seems like an axle. if you put it in gear and relase the clutch pedal and it doesnt move anywhere most likely it is your axle. or axles
Old Nov 25, 2007 | 09:55 PM
Hamstr323's Avatar
Default Re: (FLATBUSH PROJECTS)
same happened to me got it towed home checked both axels pulled one and found out my diff blew to ****!
Old Nov 26, 2007 | 12:14 AM
Fat Chick Magnet's Avatar
same thing everyone said.. axle(s). probably popped out of place from launching.
but curious to know if you even broke in your clutch before drag racing.
Old Nov 26, 2007 | 06:20 AM
Teamdiesel's Avatar
Of course the clutch was broken in. I noticed that two races before it gave, that i had to press further on the clutch to get engagement. I don't think that my axle broke because when i did that last run the car didn't even move or spin tire an inch. I just put it in gear, dropped the lever and mashed gas, but it only reved out. There was no initial movement of the tires to provide resistance to brake axles, if you know what i mean.
Old Nov 26, 2007 | 07:39 AM
Default Re: (Teamdiesel)
So have you checked out the axles yet?
Old Nov 26, 2007 | 07:42 AM
Teamdiesel's Avatar
no, not me, my mechanic hasn't called me yet but he suspects that it was clutch related.
Old Nov 26, 2007 | 07:48 AM
It sounds like an axle problem, hopefully, that's a cheap fix.
Old Nov 26, 2007 | 09:08 AM
4g hatch's Avatar
Default Re: (all-mtr-teg)
if the axle poped out wouldnt the speeedo keep moving. sounds like a clutch problem since you noticed it alittle before it wen out
Old Nov 26, 2007 | 09:46 AM
bjones's Avatar
Default Re: (4g hatch)
was the throwout bearing properly installed?
Old Nov 26, 2007 | 02:40 PM
Teamdiesel's Avatar
thank everyone that gave an input because it did turn out to be the axle. It was the one on the intermideate shaft side, and it cut clean ride inside the cv.
lopezchris21
25
Nov 19, 2023 08:24 PM
buymesomedunks
Jul 13, 2013 10:30 PM
Teamdiesel
Nov 26, 2007 11:09 PM
mikeycivic
Jun 4, 2007 05:32 PM
ctownintegra
Sep 14, 2006 07:47 AM
