questions about rebuilding my h23a1
Old Nov 25, 2007 | 04:09 PM
jprelude92's Avatar
Default questions about rebuilding my h23a1
i took apart my h23a1 turbo and found pieces of all 4 pistons were broken and there was metal shavings in the oil pan coming from the main bearings, so im debating whether to rebuilt the same engine or to buy a jdm.
if i rebuilt the same engine a wanna go with lower compression pistons,rods , if anyone has done an h23 turbo built i would appreciate if you could help me with mine.thanks
Old Nov 25, 2007 | 06:03 PM
98vtec's Avatar
moderator emeritus
Default Re: questions about rebuilding my h23a1 (jprelude92)
how badly scarred are the cylinder walls? you need to have the cylinder walls checked with a bore gauge to check for egging. You also will need to have the mains and rod journals checked because you obviously fucked something up bad.
honestly, it would probably be cheaper to find another motor.
Old Nov 25, 2007 | 06:54 PM
AndyD's Avatar
Default Re: questions about rebuilding my h23a1 (98vtec)
I think a JDM F22B is calling your name!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
honestly, it would probably be cheaper to find another motor.</TD></TR></TABLE>
.......and less headaches.
Old Nov 25, 2007 | 06:59 PM
Hawkze_2.3's Avatar
Default Re: questions about rebuilding my h23a1 (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">I think a JDM F22B is calling your name!
And if you say all 4 pistons were cracked and the mains were spun then have a LOT of work to get that block going again! Getting it re-sleeved would probably be more than a used F22B or H23.
Old Nov 27, 2007 | 02:32 PM
jprelude92's Avatar
if i was gonna do a jdm f22b swap on my h23 prelude how mamy mods would i have to do?
Old Nov 27, 2007 | 03:36 PM
jprelude92's Avatar
the cylinder walls are ok,all i have to do is just hone them, the crank is gotta come out to have it turned .
Old Nov 27, 2007 | 03:41 PM
jprelude92's Avatar
Default Re: questions about rebuilding my h23a1 (Hawkze_2.3)
the ringlands on all 4 pistons were cracked, the main bearings did not spin they just had a lot of wear on them.
chineseflyrice
Sep 5, 2007 07:02 PM
nexxxt
Apr 7, 2007 07:29 PM
mygfs92lx
Jul 24, 2006 04:24 PM
the.hamburglar
Sep 25, 2005 08:38 AM
NiiS
Jun 29, 2003 04:16 PM
