DID a compression test on my turbo db8 today good or bad numbers?HELP
Old Nov 25, 2007 | 03:50 PM
HondaEF8R's Avatar
Default DID a compression test on my turbo db8 today good or bad numbers?HELP
1 195 2 180 3 180 4 185
added oil n did it agian
210 200 220 220
all these test were done with wot n warmed up engine
my car is smoking white with a little blue to it im thinking its the rings i want to noe forsure let me noe
going to do leakdown soon just want to noe if i can find the prob with just a comp test
Old Nov 25, 2007 | 04:57 PM
blueDA9's Avatar
Default Re: DID a compression test on my turbo db8 today good or bad numbers?HELP (HondaEF8R)
It's not really the numbers that matter, it's the consistency between them that matters, those numbers are good, it could still possibly be your oil rings, not the compression making rings. Have you tuned your car for the turbo?
Old Nov 25, 2007 | 05:02 PM
HondaEF8R's Avatar
Default Re: DID a compression test on my turbo db8 today good or bad numbers?HELP (blueDA9)
yeah car is tuned
Old Nov 25, 2007 | 05:23 PM
toofast4u752's Avatar
if your really want to know how the motor is doing do a leakdown test.... and youd be able to pinpoint valves,rings ect...
Old Nov 25, 2007 | 06:07 PM
integraRS-T's Avatar
ur good thats some good nr as long as u get up to -+20 between cylinders ur good
Old Nov 25, 2007 | 06:58 PM
HondaEF8R's Avatar
Default Re: (integraRS-T)
ok leakdown test time
humboldt_skim
May 31, 2008 08:18 AM
Azcheron
Jun 23, 2005 09:34 PM
Pfieff
Mar 8, 2004 07:19 PM
DxTrix
Aug 15, 2003 04:58 PM
Propulsion
Jun 5, 2002 11:48 PM
