50 paint job
Old Nov 25, 2007 | 03:36 PM
kixcrx's Avatar
Default 50 paint job
ok so im going to start my 50 dollar paint job but i just wanted to make sure if im got the right list of things im going to get so this is what im going to get if im missing something please let me know before i go to the store.
1. 1 can of primer
2. rustoleum paint 1 gallon
3. thinner- mineral spirits
4. high density rollers
5. tray
6.tape blue
7.sanding block
8.sand paper 320,600,800,1500,1000,2000
am i missing anyhting
Old Nov 25, 2007 | 04:08 PM
fastedie's Avatar
Default Re: 50 paint job (kixcrx)
depends on the condition that the clear is in...... Some times with our hondas youll find the clear like to flake of if so you need to remove all clear and it will take 150 grit to get it off unless you want to be there for a while other than that looks good.. Im still in prep have been for two weeks post pics when you can ill do the same....What color?
Old Nov 25, 2007 | 06:29 PM
kixcrx's Avatar
Default Re: 50 paint job (fastedie)
it is going to be gloss black. I already had taken off the clear before a long time ago when i though i was going to take it to get painted but didnt have no money so i ended up spray painting it flat black with cans. So all i have to remove is the spray paint, and im doing that with a 320 ill post pics later.
Old Nov 25, 2007 | 08:56 PM
bleakdragonmage's Avatar
i thought you didnt need a primer cuz the rustoleum is everything in one??
Old Nov 25, 2007 | 09:40 PM
kixcrx's Avatar
Default Re: 50 paint job (bleakdragonmage)
i used the primer on spots where u can see some bondo and some metal spots
Old Nov 25, 2007 | 10:31 PM
kixcrx's Avatar
everytime i primer a spot i have to sand down that spot right and with what sandpaper
Old Nov 26, 2007 | 06:21 AM
fastedie's Avatar
320 will do just fine
Old Nov 26, 2007 | 09:48 AM
kixcrx's Avatar
this is what i have done so far just started yesterday, i sanded down my whole roof and primed it allbecause off alot of metal spots showing then i moved on to my hood and its taking forever i think i need to move on to an electric rotating sander. Still need to sand down prime on roof
Old Nov 26, 2007 | 03:37 PM
fastedie's Avatar
Looks like your make good progress
Old Nov 26, 2007 | 11:08 PM
kixcrx's Avatar
ok so i got home form work and started to work on car first i did the roof.I sanded down the primer till it was smooth then i cleaned it off with some mineral spirits. Then i prepared my paint and stirred, hope i mixed it right, i put like half and half well a little bit less of paint then i put my first coat. These are the pics of the first cost without sanding yet paint is still fresh. I also got alot of little dots and orange peel could it be maybe because i didnt sand it down yet. And i sand down after second coat right with 320.
Old Nov 27, 2007 | 10:38 AM
accent0002's Avatar
looks like you put it on a little to thick for a first coat
Old Nov 27, 2007 | 10:51 AM
kixcrx's Avatar
Default Re: 50 paint job (accent0002)
yeah i think it looks like that because the paint was still fresh, i had just put it on . But right now it doesnt look like that anymore. Now im going to put my second coat on.
Old Nov 27, 2007 | 11:12 AM
fastedie's Avatar
just a tip for this proccess the thinner you put on the better! I was looking at the picture of your hood I have seen this a few times and for some reason it keeps catching my eye did how coarse did you go when blocking it looks like there are some serious dips in the sand job which will be a pain in the *** to get out! also why is the hood so muddy murky looking ? just curious bro
Old Nov 27, 2007 | 11:43 AM
kixcrx's Avatar
what do yo mean by muddy and murky, because of the water sanding or something else
Old Nov 27, 2007 | 07:44 PM
fastedie's Avatar
just wondering what that mess on your hood is it looks blotchy just wondering why it was so messy mine didnt look like that.
Old Nov 28, 2007 | 03:25 AM
SincereLEE's Avatar
i started the sanding today im going with safety red on my dc2
Old Nov 28, 2007 | 04:26 AM
daddy's Avatar
Default Re: 50 paint job (SincereLEE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastedie &raquo;</TD></TR><TR><TD CLASS="quote">just wondering what that mess on your hood is it looks blotchy just wondering why it was so messy mine didnt look like that.</TD></TR></TABLE>
it looks like he's not done sanding the hood in that pic
Old Dec 3, 2007 | 10:27 PM
kixcrx's Avatar
Default Re: 50 paint job (daddy2be)
ok so i think i finished it i only put five coats i dont think i needed that many because my car was already black. It does kinda have a gloss to it but at the same time it looks dull i think its myabe because i havent sanded it down with the 1500 and 2000 and polished yet but heres a pic of the hood ill try to take more of the side of the car later
Old Dec 5, 2007 | 06:13 PM
fastedie's Avatar
looks good bro lets seem some pics of it Rollin out!
Old Dec 5, 2007 | 10:30 PM
kixcrx's Avatar
ok so i barely got home from work and went outside and took some pics i know they might look kinda dark but ill try and take some in daylight when i have some time. In these pics i still havent done the final wetsanding with 1500 and 2000 or the buffing still giving the paint some time to cure,dry.
on this pic u can see it kinda has a gloss to it
this is the other side of the car. The car is kinda dusty as u can see on the nest pic how i left my finger marks
Old Dec 6, 2007 | 05:45 PM
fastedie's Avatar
Nice Were are you located was it cold
when you painted
Old Dec 6, 2007 | 10:22 PM
kixcrx's Avatar
yeah it was freezing i had to wait like a day everytime i painted a coat because it would take forever to dry.
KILLAB17VTEC
Paint and Body
10
May 1, 2009 02:16 PM
-=ZAK=-
21
Feb 3, 2009 04:06 PM
d-series guy
68
Jan 11, 2009 11:41 AM
WarpFactorVIII
Paint and Body
Sep 5, 2007 10:55 AM
Roses.Are.Red
Nov 18, 2006 07:11 PM
