Prelude stock fuel injectors
not 100% sure if this site is accurate but i am pretty sure.
http://www.allmotorhonda.com/t...r.htm
1992-96 Prelude non-vtec Peak and hold 240cc
1992-96 Prelude VTEC Peak and hold 345cc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp3nce »</TD></TR><TR><TD CLASS="quote">thanks 98vtec.
another quick question while im on here, not relating to the OP.
what computer/ecu/chip should be running with a 5spd? I have a swap, but still the auto ecu. </TD></TR></TABLE>
you can turn your auto ecu into a manual, just search here on H-T
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude »</TD></TR><TR><TD CLASS="quote">
you can turn your auto ecu into a manual, just search here on H-T</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1275452
That site is currently closed down. I just wanted to make sure that the stock injectors are 345cc I'm currently having problems with my 94VTEC engine in my 96 Prelude. Hondata's calibration for the prelude puts the injectors at 310cc stock and 450cc current. I tried setting it to 310cc and it ran fine until the VTEC kicks in at 5000 then it starts jerking. So I have it set at 410cc now and it seems to be doing alright. It was running lean, not sure if it still is, but I'll try the 345cc setting and read the lambda I guess.
Thanks,
-Jus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 »</TD></TR><TR><TD CLASS="quote">not 100% sure if this site is accurate but i am pretty sure.
1992-96 Prelude VTEC Peak and hold 345cc</TD></TR></TABLE>
Thanks,
-Jus
GirlNALude
Jan 20, 2004 07:07 PM
