42mm offset question!
Old Nov 25, 2007 | 10:50 AM
slacks's Avatar
Default 42mm offset question!
I found a pair of Enkei wheels to get, but the only problem is a +42mm offset. What would I do about tires on these? Would 215/40/16 work? or 215/45/16? Both? Which would be better?
Already tried searching too.
http://cgi.ebay.com/ebaymotors...=true
that's the link for the wheels if it helps
Old Nov 25, 2007 | 12:23 PM
Voyage34's Avatar
Default Re: 42mm offset question! (slacks)
the car these will be going on will determine your ideal tire size. If theyre going on a 95/earlier civic, you should get 205/40/16, if theyre going on a 96-00 civic or any year (iirc) integra, its a tossup between 205/45/16 and 215/45/16, depending on your preferred tire's size availability.
+42mm offset shouldnt be any issue, since most honda applications are in the +45 range.
Old Nov 25, 2007 | 01:54 PM
slacks's Avatar
Default Re: 42mm offset question! (Voyage34)
awesome!
that's what i was hoping for
they're going on a 94 civic so thanks for the help!
any thoughts on the wheels by chance? (just since it's ebay).
Old Nov 25, 2007 | 01:56 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">the car these will be going on will determine your ideal tire size. If theyre going on a 95/earlier civic, you should get 205/40/16, if theyre going on a 96-00 civic or any year (iirc) integra, its a tossup between 205/45/16 and 215/45/16, depending on your preferred tire's size availability.
+42mm offset shouldnt be any issue, since most honda applications are in the +45 range.</TD></TR></TABLE>
Correct except (a) the best offset depends on the wheel width, which hasn't been stated, and (b) the '96 Civic is a bastard - the DX and hatchback models need the same size tires as the '95/earlier, and only the other models need the same size as the '97-00.
Old Nov 25, 2007 | 02:07 PM
slacks's Avatar
Default Re: 42mm offset question! (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks &raquo;</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...=true
the wheels are 16x7"
Baggy Spandex
Jul 26, 2014 06:27 PM
BMRALR
Feb 8, 2009 08:30 PM
zexifiedlude
Jan 26, 2006 03:29 PM
PA Geesir
May 3, 2004 04:58 PM
slowacura
Mar 25, 2003 09:50 PM
