98-00 gsr motor in 96 hatchback?
Old Jun 25, 2002 | 09:08 AM
-Darren-'s Avatar
Default 98-00 gsr motor in 96 hatchback?
is that a straight swap or not? meaning do i need to do some type of obd I to obd II conversion. stuff like that.
Old Jun 25, 2002 | 09:37 AM
B-series Assassin's Avatar
Default Re: 98-00 gsr motor in 96 hatchback? (blkgti)
No because your 96 hatch is OBDII.
All cars 96-up is OBDII.
Old Jun 25, 2002 | 11:06 AM
-Darren-'s Avatar
Default Re: 98-00 gsr motor in 96 hatchback? (B-series Assassin)
so are u telling me no it's not a straight swap and that i need to do an obd I conversion.
Old Jun 25, 2002 | 11:12 AM
98DC2's Avatar
Yes, it will bolt in w/ out much trouble. Your engine & car are both OBD2, so therefore you can use stock harness from GSR along w/ GSR ECU. The only time you would need to use a OBD1 harness is if either your car / engine were diff. since both are OBD2, you are straight. Make sure you properly wire knock sensor!!! this can be tricky. Good luck!
[Modified by 98lagen, 8:14 PM 6/25/2002]
Old Jun 25, 2002 | 11:31 AM
-Darren-'s Avatar
Default Re: 98-00 gsr motor in 96 hatchback? (98lagen)
thanks for clearing that up.
Old Jun 25, 2002 | 03:50 PM
1 2 NV's Avatar
99-00 GSR ECUs will not plug into ur harness, u need 96-98 GSR ECU.
Old Jun 25, 2002 | 06:50 PM
-Darren-'s Avatar
Default Re: 98-00 gsr motor in 96 hatchback? (hondaatwsu)
why not.
Old Jun 25, 2002 | 08:00 PM
1 2 NV's Avatar
99-00 honda changed the plugs that go into the ECU. if i remember correctly and this could b backwards the 96-98 ECUs had A, C, and D plugs where the 99-00 cars had A, B, D plugs. i repinned my 99 car to 98 specs. its only 56 wires but it took 2 hrs. if i had another pair of hands it would have gone much faster.
Old Jun 25, 2002 | 11:54 PM
-Darren-'s Avatar
i understand now thanks.
Old Jun 26, 2002 | 06:46 AM
Slopoke's Avatar
Your engine & car are both OBD2, so therefore you can use stock harness from GSR.....
This is incorrect. You cannot use the GSR harness in 6th gen civics. You must reuse your stock civic harness and add the necassary wires.
Old Jun 26, 2002 | 08:42 AM
kenji's Avatar
Default Re: 98-00 gsr motor in 96 hatchback? (Slopoke)
These are the facts:
If you have a '96 Civic a '96-'99 Integra ECU WILL plug into your engine harness. The '00-'01 ECU plug style is different than the '96-'99 and the '94-'95.
You need to use your Civic engine harness and modify it to fit on the GS-R swap.
You can switch to OBD1 if you choose. But, it is not necessary.
Trey on these boards has the link to a 6G Civic swap page.
-kenji
ThrowSomeDs
11
Jun 14, 2011 08:32 AM
dc4teggiehatch
Nov 25, 2007 05:54 PM
NETAMI
Jun 22, 2006 08:38 AM
ubreak_ubuy
Aug 5, 2005 09:54 AM
ksilaphet
Jul 18, 2003 12:07 PM
