misfiring (I think)
Old Jun 25, 2002 | 09:05 AM
servion's Avatar
Default misfiring (I think)
It's like a misfire... I give it gas at low rpms (pretty much anything over 1/2 throttle) and it bogs and feels like its misfiring.... but only low rpms (like 2000rpms in 4th or just starting off in 1st). you can hear it in the exhaust.... it pulsates, so it seems like its not always firing... but I changed my entire ignition system. Plugs, wires, cap, rotor, added an MSD /w blaster 2 coil in my jdm h22a. Checked fuel pressure...about 2 psi high at idle /w the vacuum lines atatched to the FPR. but not too bad. What else would cause a misfire?
If its not a misfire, what else could it be?
Old Jun 25, 2002 | 11:38 AM
servion's Avatar
Default Re: misfiring (servion)
did a compression test... 202 202 192 202
Old Jun 25, 2002 | 11:39 AM
YeuEmMaiMai's Avatar
clogged injector
Old Jun 25, 2002 | 12:02 PM
servion's Avatar
Default Re: misfiring (YeuEmMaiMai)
I currently have a can of BG 44k in the tank and I've burned about 1/2 the tank. It also only happens at low rpms.. I can open the trhottle plate by hand under the hood and it will do it until it gets to a certain rpm (probably around 3k or so it stops)
Old Jun 25, 2002 | 04:01 PM
Mikey3000's Avatar
check your plugs to see if it's running rich. if it is, you prolly have some plugs mixed up. some may not give a CEL.
Circaskaterr
Mar 15, 2016 02:18 PM
nine23
Jan 18, 2009 01:33 PM
Teh_Oven
Nov 5, 2004 05:36 AM
pelotudo
Sep 11, 2002 06:47 PM
nijia555
Jun 4, 2002 04:37 AM
