should i switch wheels?
i have these 17' pinnacle wheels on the teg now, but im considering to buy some sportmax 501's. What are ur alls opinions? Buy the sportmax wheels or keep the ones i have??
Don't get wheels this
[__________________________________________________ ___] wide
with tires this
.\__________________________________/ wide
that stick out
past the fender this
F]
E]\
N]-\
D]--\
E]---\
R]----\
]]]-----T
]]]-----I
]]]-----R
]]]-----E
much
What you have now looks good to me.
with tires this
that stick out
F]
E]\
N]-\
D]--\
E]---\
R]----\
]]]-----T
]]]-----I
]]]-----R
]]]-----E
much
yeah i know its my car, and not HT's. i just wanted some insight. I really want to get the sportmax wheels bc i htink they'd look sexy, but the ones i have now go well with the car also. im going nuts. lol.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteSlipsWithStickers »</TD></TR><TR><TD CLASS="quote">Don't get wheels this
with tires this
that stick out
F]
E]\
N]-\
D]--\
E]---\
R]----\
]]]-----T
]]]-----I
]]]-----R
]]]-----E
much
What you have now looks good to me.</TD></TR></TABLE>
lol and if i get the 501's with the +15 offsett what tire should i get?? to make it not stick out soo much?
with tires this
that stick out
F]
E]\
N]-\
D]--\
E]---\
R]----\
]]]-----T
]]]-----I
]]]-----R
]]]-----E
much
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** 1.6 »</TD></TR><TR><TD CLASS="quote">those 17s actually look pretty good on your car... but the ther ones are gonna be hawt!</TD></TR></TABLE>
i agree, they look really nice(your current set)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKris »</TD></TR><TR><TD CLASS="quote">
Those come in an 8" wide wheel with a +15 offset I believe, so you'd have to get a 185 or 195 tire which is meant for a 6"-6.5" wide wheel. You will be driving on the sidewall of your tire when taking corners at normal speeds. I don't know about you, but that doesn't sound safe at all. Plus 15's usually look horrible on integras. Keep what you have now or get a wheel in 16's with the same width and offset of your 17's. It's totally up to you, but to me those 501's would ruin your clean car.
Those come in an 8" wide wheel with a +15 offset I believe, so you'd have to get a 185 or 195 tire which is meant for a 6.5" wide wheel. You will be driving on the sidewall of your tire when taking corners at normal speeds. I don't know about you, but that doesn't sound safe at all. </TD></TR></TABLE>
yeah thats def. not safe. i went through the offset wheel thread, ppl are using 205's. Do those sound good?
yeah thats def. not safe. i went through the offset wheel thread, ppl are using 205's. Do those sound good? </TD></TR></TABLE>
Those sound good except I've got 205-40-16's on a 7" wide wheel and +35 offset and I've got about [---] that much space in the front and rear before they rub. You are going to have to roll your fenders and pray you don't have to take a corner at full lock or bye bye tires, bye bye car.
yeah i was planning on rolling the fenders so they dont rub, and is flushed. But that last part kinda scares me....bye bye tires, bye bye car..
. if i do get the wheels, i def dont want them to stick out alot tho. =/
16x7 +32 with 205-45. PERFECT offset and tire size for Integras. Think long and hard before dropping cash on some played out chinese wheels, stretched tires and hating life when you cut a tire on your rolled fenders.
ok so heres some proff that not all low-offset wheels look that bad.....these are 16's with 0 offset....(i will remove upon owners request)....but yeah it is ur car so u do whatever u like, i just get bored of wheel fast so i always endup changing them....i like trying new things out
I think your wheels look fine. They're one inch to big for my taste, but I think they look fine on your car.
In the end, you should do what you want, regardless of what we think.
wow that DA is nice. It looks so flushed with the fnders and car. A lot of rolling? so if thats a 0 offset, then the +15 would look as good. Do you know what kind of tire he used?
