mugen header with b18b
Old Nov 24, 2007 | 06:46 PM
AcuraTilIDie's Avatar
Default mugen header with b18b
Will mugen header fit b18b motor without any modification. If not, what mods will need to be done? Thanks in advance
Old Nov 24, 2007 | 06:49 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: mugen header with b18b (AcuraTilIDie)
Um, if the header is for that car, then yes, it'll work...
Is it from a diff. car???
Old Nov 24, 2007 | 07:14 PM
sleeperrex's Avatar
Default Re: mugen header with b18b (Byaaah!)
i cann only think of one mugen header hes talking about, and i know they fit bseries vtec heads, not too sure of ls motors.
The header is for a type r which has a b18c5 so I don't know what I would need to do, if anything, to make it fit my LS B18b motor.
Old Nov 24, 2007 | 09:47 PM
wow, no one knows???
Old Nov 24, 2007 | 09:54 PM
dcRay's Avatar
It will definitely fit on the LS block, but you will have to modify the flange bolting to the cat because the mugen header probably have a 2.5" flange.
Old Nov 24, 2007 | 09:57 PM
Default Re: mugen header with b18b (dcRay)
so what if i run the Mugen header onto a Mugen exhaust?
Btw, how sure are you that the header will bolt right up to the LS block?
Old Nov 24, 2007 | 10:09 PM
{Sigur-Ros}'s Avatar
props to your header buddy i hope you get the info
Old Nov 24, 2007 | 10:13 PM
SYTFU Tommy.'s Avatar
Default Re: mugen header with b18b ({Sigur-Ros})
the header itself will bolt onto the motor, the only thing you will have to do to make it fit is the bpipe or the cat depending if the header. the bpipe will either needed to be extended or shorten then also the flange might need to be changed also if the header flange is larger.
Old Nov 24, 2007 | 10:18 PM
Default Re: mugen header with b18b (SYTFU Tommy.)
i was really hoping it was just plug and play
Old Nov 25, 2007 | 05:38 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcuraTilIDie &raquo;</TD></TR><TR><TD CLASS="quote">so what if i run the Mugen header onto a Mugen exhaust?
Btw, how sure are you that the header will bolt right up to the LS block?</TD></TR></TABLE>
You will need a different catalytic converter. Is the Mugen exhaust (I assume twin loop) modified for USDM catalytic converters? King Motorsports did modify these to fit.
The header will bolt to the B18B head with no problems.
2LEM1
Mar 12, 2012 07:35 AM
BLACKISWHACK
11
Apr 13, 2005 02:15 PM
JDMluvR
Mar 15, 2004 09:10 PM
kidzoom206
Oct 31, 2003 01:31 AM
