built 2.0 gsr comp test
Old Nov 24, 2007 | 02:05 PM
builtturboeg's Avatar
Default built 2.0 gsr comp test
did a comp test on my new motor and cyl # 1 was 90 psi cyl # 2,3,4 were 170psi
any ideas on what it could be engine only has 10 min running at idle
Old Nov 24, 2007 | 02:24 PM
crl3vtec's Avatar
Default Re: built 2.0 gsr comp test (builtturboeg)
did you adjust your valves.... is timing on... possibly the rings havent sealed yet... go drive it and downshift and let the motor to slow you down to seat the rings do that for about 20 miles or so.... and then check it again.... did y ou have the head checked out before for any messed up valves... .who built the motor someone reputable
Old Nov 24, 2007 | 02:42 PM
head has brand new skunk2 valves ,springs retainers pnp 3 angle valve job valves were not adjusted yet timing is on did a wet comp test and no change cant drive it yet wont idle right
Old Nov 24, 2007 | 03:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (builtturboeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builtturboeg &raquo;</TD></TR><TR><TD CLASS="quote">head has brand new skunk2 valves ,springs retainers pnp 3 angle valve job valves were not adjusted yet timing is on did a wet comp test and no change cant drive it yet wont idle right</TD></TR></TABLE>
i think you need to start there.
Old Nov 24, 2007 | 07:22 PM
A.E Motoring's Avatar
Default Re: (boostedcivicsir)
x10
loc_yaj
Apr 12, 2008 06:45 PM
eg6_rick
Dec 30, 2006 01:53 PM
9hatchman4
Jul 13, 2006 07:42 PM
94SuperLudeSI
Jan 12, 2006 03:14 PM
SQURL
24
Oct 23, 2004 08:21 PM
