Checking valves on a gsr?
Old Jan 12, 2006 | 12:33 PM
94SuperLudeSI's Avatar
Default Checking valves on a gsr?
I have 1 92 gsr and it was idealing one night and timing jumped. I dont know for sure if it bents valves but how do you check them?
Old Jan 12, 2006 | 12:36 PM
DJ Gurgla GSR's Avatar
Default Re: Checking valves on a gsr? (94SuperLudeSI)
the timing belt jumped a tooth? did you correct that?
a leakdown test will tell you whether the valves are bent or not
Old Jan 12, 2006 | 02:44 PM
Dogginator's Avatar
Daisy... Daisy...
Do a compression check. It is far easier and cheaper than a leakdown test.
Old Jan 12, 2006 | 03:14 PM
I probally pull the head off and have a valve job done and new skunk2 valves or something. See what i have is a crx si blown up and i am sticking a b17 in it but the belt jumped a couple of teeths i forget how many tho. But i just want to here the b17 run befor i'll i take it out of my teg then i just want it in the crx and I want to hear it run then barely drive it and just pull the head and have a valve job done to it and new valves to.
PURPLERANGER
Aug 9, 2014 05:43 AM
gsr96cx
Aug 27, 2008 04:33 PM
loc_yaj
Apr 12, 2008 06:45 PM
loc_yaj
Apr 12, 2008 06:40 PM
94SuperLudeSI
Jan 16, 2006 10:22 PM
