got the h22 tuned. is this right?
Old Nov 24, 2007 | 12:15 PM
whatever210's Avatar
Default got the h22 tuned. is this right?
hey whats up guys. i recnetly swaped a h22 in my cb7. ive been on cb7tuner.com for a while. i recently got it dynoed and tuned. my question is how does this look for a stock internals with a cai, and 2 inch pipes, header, fuel pressure regulator and chipped p28. some one said that the vtec enagement point was to drastic. they also said that they retarted my timing and then when vtec kicked in they advanced the timing like crazy. let me know what you guys think.
Old Nov 24, 2007 | 12:31 PM
alterdcreations's Avatar
Default Re: got the h22 tuned. is this right? (whatever210)
looks good to me for a stock swaped h
Old Nov 24, 2007 | 12:41 PM
^ thanks! your the first to say it looks good. lol everyone expects it to have more power. i guess since i said it was tuned it should have more power.
Old Nov 24, 2007 | 12:56 PM
DC209's Avatar
looks ok good luck with the project
Old Nov 24, 2007 | 01:12 PM
D-Rob's Avatar
Default Re: got the h22 tuned. is this right? (DC209)
Looks fine to me. The VTEC engagement point may need some moving around, but that's about it.
- Derek
Old Nov 24, 2007 | 01:27 PM
BolivianFuego's Avatar
Default Re: got the h22 tuned. is this right? (D-Rob)
Yea it looks ok for what it is. Do you have Power Steering hooked in? And whats the header?
If you want the most power, go some sort of EMS like hondata, and get that baby tuned for your car.
Old Nov 24, 2007 | 01:46 PM
its a cheap ebay header. just enough to get by right now. the jdm header doesnt mate with usdm down pipe so i had to get a cheap on right now. also im still using the stock down pipe and collecter from the f22a6.
Old Nov 24, 2007 | 01:47 PM
Yea that power is fine. Get it retuned on a good header and you'll be making high 180s with PS, and 190ish with no PS.
Old Nov 24, 2007 | 04:06 PM
I smell secretions's Avatar
From: Looking for Vagina in your Mamma,, skeet skeet
Default Re: got the h22 tuned. is this right? (BolivianFuego)
youi said that you tuned it...with what?
Old Nov 24, 2007 | 04:13 PM
mgags7's Avatar
Default Re: got the h22 tuned. is this right? (I smell secretions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I smell secretions &raquo;</TD></TR><TR><TD CLASS="quote">youi said that you tuned it...with what?</TD></TR></TABLE>
an fpr and a chipped p28.
Hondata isn't really necessary for this guy....the guy that did the chip did a good job with it, all he needed to do was burn a chip for the ecu. AF looks like y0 momma's chest
I would say the torque looks a bit low, which explains the lower peak hp of course. It could probably be linked to the fact that you have a 2" exhaust. Open that thing up with a nicer header and a bigger exhaust.
Old Nov 24, 2007 | 04:15 PM
Default Re: got the h22 tuned. is this right? (mgags7)
Yea the AF isnt bad, im sure with some messing with the timing and the AF some more though, theres alot more left in her!
With a 2.5 inch exhaust and tuning given it is a strong motor, along with a good header i dont see why you couldnt come close to cracking 200whp and 16xtq.
Old Nov 24, 2007 | 04:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
lol. but yeah getting bigger pipes will help the flow of things a little better.
Old Nov 24, 2007 | 04:27 PM
Evolution Type R's Avatar
looks good!
I think the exhaust is whats holding your power back. I bet if you would put a 2.5inch or even 2.75inch with a good header you would make alot more power
Old Nov 24, 2007 | 04:38 PM
v4lu3s's Avatar
RTFM
power output is very comparable to both h22's i dynoed in my car with a cold air intake, jdm oem header and apexi dunk exhaust with a stock p13. looks good to me, and with a better header and exhaust im sur eyou can do better.
Old Nov 24, 2007 | 06:20 PM
Default Re: (v4lu3s)
whats the biggest exhaust you guys would personaly go 2.5 or 3. im running cheap ebay header because the jdm wouldnt bolt up to the usdm down pipe. but im running the stock down pipe as well. (f22a6)
Old Nov 24, 2007 | 07:58 PM
Fat Head
Guest
Posts: n/a
Default Re: got the h22 tuned. is this right? (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote"> looks good to me for a stock swaped h</TD></TR></TABLE>
Old Dec 1, 2007 | 10:28 AM
Default Re: got the h22 tuned. is this right? (Fat Head)
went to silverdollar raceway in ga this friday and in a quater mile i ran a 14.8, is that good bad or what. and my tires are bald and i couldnt drop from anywhere over 1500 rpm or i would spin all the way through 1st and suck up sencond.
Old Dec 2, 2007 | 05:35 AM
flyrod's Avatar
That tune looks pretty good for a generic "chip." You could lower the VTEC switch point to smooth out the torque curve, but it's already low enough that you won't be dropping out on shifts. If you hook up the IAB you could get a little more torque on the low end (below 4.5k), but you'd need to modify the ECU and get a "chip" that is set up right.
Add this to the H22 dyno thread!
Old Dec 2, 2007 | 07:30 AM
gibsanez's Avatar
Default Re: got the h22 tuned. is this right? (flyrod)
Why does the crossover on the H22's always seem so aggressive?
Old Dec 2, 2007 | 01:57 PM
flyrod's Avatar
Default Re: got the h22 tuned. is this right? (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">Why does the crossover on the H22's always seem so aggressive?</TD></TR></TABLE>
I think it's because it should be lower for a smooth transition, but if Honda set it at 4k then there would be a lot of H22's cruising the highways in VTEC.
Old Dec 3, 2007 | 05:44 AM
A BOOSTED CRX's Avatar
nah, everything looks extremely smooth, a/f is almost perfect, vtec engagment is a bit drastic, but like other people said, it looks good for a basically stock h22..
good luck in the future
and the main question should be: Do you like how it run's? thats all that matters, not other people...its your car.
bassfreq
14
Mar 25, 2010 03:07 PM
lsvtecndx
Oct 10, 2006 06:18 PM
h23turbo
Jul 17, 2004 11:04 AM
