How do I take off my Tints??
i just got a fix-it ticket for my tints ON THE FREEWAY....****** cop. how do i take off my tints. my friend told me that i had to get amonia and spray it on my window on a really sunny day and then put a plastic bag over it and let it sit for about 3 hours and to peel it off. is this right?? help please.
Heat gun or hair dryer will work, just peel it off. You'll have to go back with cleaner and a razor blade to get the glue off. Tint-free looks better anyway
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by billboard »</TD></TR><TR><TD CLASS="quote">pay a tint shop to do it...
its not worth doing it yourself...
its def a PITA project...</TD></TR></TABLE>
Yea probly the best idea. I always wondered what places charge to do that, any idea?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR Rodgers »</TD></TR><TR><TD CLASS="quote">
Yea probly the best idea. I always wondered what places charge to do that, any idea?</TD></TR></TABLE>
my brother did at a local tint shop, 70bucks to remove tints on his DB, back and 4 sides..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brewer »</TD></TR><TR><TD CLASS="quote">Heat gun or hair dryer will work, just peel it off. You'll have to go back with cleaner and a razor blade to get the glue off. Tint-free looks better anyway
x2 I borrowed a heatgun from a friend and you just heat up the tint little sections at a time until it starts to shrink. (Start with the corners and just peel as you heat up the tint in front of you.) It will all come off. If you are smooth with pulling the tint off, there should be a minimum amount of glue residue left.
To remove the rest, I suggest a big bottle of Goo Gone, a cotton cloth, and some elbow grease!
</TD></TR></TABLE>x2 I borrowed a heatgun from a friend and you just heat up the tint little sections at a time until it starts to shrink. (Start with the corners and just peel as you heat up the tint in front of you.) It will all come off. If you are smooth with pulling the tint off, there should be a minimum amount of glue residue left.
Goto walmart and buy a can of Tuff Stuff (upholstery/vynil) cleaner. it eats away the glue and you can take some steelwool (mild or fine) or scotch bright and scrub it off, it wont scratch the glass and it basicly desolves it away.
1. rip off the tint, side windows are easy but the back window has a defroster line that you cant break because the defroster wont work if you do.
2. once you take off the tint you will probly have glue left on the window
3. spray TuffStuff onto the whole window
4. let it eat at it for a few seconds
5. scrub with steel wool or scotch bright
6. then wipe away all the goop
7. reclean with window cleaner
AND YOUR DONE!!!!!
redo on each window and you will be tint free in no time!
AND YOUR DONE!!!!!
the heat gun is ok if you have paitence and a heat gun but i have tried all kinds of chemicals and all kinds of techniques and the "rip and scrub" is the best method to me. but it all depends, if your window tint is still new it might all come off without glue residue, or minimal glue left. either way tuffstuff is definatly better then amonia, goo gone, etc. trust me on this one. you might spend $5 on tuffstuff and steel wool and your good to go! and its all at waltmart too!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaMan »</TD></TR><TR><TD CLASS="quote">Goto walmart and buy a can of Tuff Stuff (upholstery/vynil) cleaner. it eats away the glue and you can take some steelwool (mild or fine) or scotch bright and scrub it off, it wont scratch the glass and it basicly desolves it away.
AND YOUR DONE!!!!!
redo on each window and you will be tint free in no time!</TD></TR></TABLE>
that sounds good..my car, the last owner took the tint off and it has the glue residue all over the window, i want it to be crystal clear. thanks for the info.
AND YOUR DONE!!!!!
great im an idiot wish i woulda asked earlier i took off my tint on my rear hatch of my integra and used a razor and some spray remove tint ish from walmart...in the process i also took off the defrost lines!!....i need a new hatch...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluerims »</TD></TR><TR><TD CLASS="quote">THROW STONES TO ALL YOUR WINDOWS OR BREAK ALL YOUR WINDOWS= NO WINDOW NO TINT....PROBLEM FIXED</TD></TR></TABLE>
you must be a comedian of sorts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_B »</TD></TR><TR><TD CLASS="quote">Aircraft stripper works, just be careful with it. </TD></TR></TABLE>
wow, thats a crazy move, never had enough ***** to do that, i like to keep my interior panals from melting usually. lol
I got too many tickets w/ the tints my car came with, so i just didnt want to deal with it being a PITA so i payed a local tint shop to do it for me. Cost me about 100$ if i remember correctly.
