NEW obd1 ecu probs
ive put in my new obd1 ecu with the jumper harness, and im glad i didnt mount it bcuz i have no power, at idle it pulses insted of running clean, it seems to be a little better as rpms go up, but its hard to get them up bcuz it sputters when u step on throttle or on throttle body, and ive moved it about 40 feet doing nothing but slipping the clutch. i didnt tune it, so is this bad tuning or do i need something im missing.
Ecu Specs:
Tuned for stock injectors with boost at 6psi
launch control 4500rpms
full throttle shift 6500rpms
redline 7200 rpms
cel shift light 7000rpms
Car setup:
.50a/r turbo at 6psi
external ignition coil cap wires w/ 1 stage cooler plugs
full exhaust
plus other non-important stuff
The ecu was tuned with crome pro, i would re-tune it, but i have no tuning experience and i only have uberdata and no burner.
Any real help is appreciated.
Ecu Specs:
redline 7200 rpms
Car setup:
full exhaust
roachsboosted16
Nov 24, 2007 12:10 PM
NationsMostWanted
Jul 31, 2005 08:50 PM
