Classic Hondas All Pre-1988 Hondas.
I have a pgm-fi code 6 that will not go away.
Old Nov 24, 2007 | 11:20 AM
moonjaw2002's Avatar
Default I have a pgm-fi code 6 that will not go away on a 86 accord lxi
I have replaced and tested all associated sensors and tested the wires and connectors with a ohm meter.I have swapped the ecu with a good one and still have a code 6.The car is hard to start cold and once warm it starts and runs fine.
Will putting a block heater in make any difference with the troubles i am having now.How hard is it to put one in with the engine in the car.
Mark
Old Nov 24, 2007 | 01:08 PM
E-AT_me's Avatar
Default Re: I have a pgm-fi code 6 that will not go away on a 86 accord lxi (moonjaw2002)
what's a code 6? (too lazy to lookup right now..)
Old Nov 24, 2007 | 03:50 PM
Default Re: I have a pgm-fi code 6 that will not go away on a 86 accord lxi (E-AT_me)
Temp sensor on the thermostat housing.The black one closest to the thermostat.
Mark
Old Nov 24, 2007 | 05:40 PM
E-AT_me's Avatar
hmmm. coolant level ok?
Old Nov 24, 2007 | 06:26 PM
Yes fresh anti freeze,bleed system,fans kick on and off as they should.
Mark
Old Nov 24, 2007 | 07:55 PM
night's Avatar
not that you can't figure it out but are you sure you changed the right one?
haven't messed with one in a long time, but i believe it is the green one, the inner one?. those sensors are a common problem, even a tsb. though they usually cause a hot soak and flood it once warmed up.
the other one is for the a/c fan control.... i think.
Old Nov 25, 2007 | 06:46 AM
Default Re: I have a pgm-fi code 6 that will not go away on a 86 accord lxi (night)
I was told by two other people it was the black sensor,but i have replaced the other one before and tested it also.
Mark
rudyndrew
Dec 30, 2010 02:12 PM
MPALUGHI
Jan 7, 2005 05:11 AM
Rob!
Dec 17, 2002 06:34 PM
White Lightnin
Jun 28, 2002 09:15 AM
crx_91si
Jan 22, 2002 05:06 PM
