Classic Hondas All Pre-1988 Hondas.
87 civic suspension.
Old Nov 24, 2007 | 08:21 AM
CivicKid517's Avatar
Default 87 civic suspension.
The suspension in my 87 is really bad.
and It's not normal suspension.
Any tips would be much appreciated.
Old Nov 24, 2007 | 11:16 AM
NW Classic Honda's Avatar
Default Re: 87 civic suspension. (CivicKid517)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicKid517 &raquo;</TD></TR><TR><TD CLASS="quote">The suspension in my 87 is really bad.
Any tips would be much appreciated.</TD></TR></TABLE>
Um ok, fix it!
Old Nov 24, 2007 | 01:10 PM
E-AT_me's Avatar
Default Re: 87 civic suspension. (jdmda7)
well, let's first off start with what you have and what you'll be doing with the car? drag racing? autocross? track days?
if you hurry, Mr. D aka heeltoeauto have one set of tien suspension left. but for a big price!
Old Nov 24, 2007 | 02:17 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Define "bad". Describe how you want it to be good? What is your budget?
Also, go here and read the FAQ, the manual,etc...
http://www.redpepperracing.com
Old Nov 25, 2007 | 11:01 AM
Default Re: 87 civic suspension. (tjbizzo)
If you hit a bump in this thing it sounds like broke the entire front end of the car.
Budget would probably be around 600 bucks.
Old Nov 26, 2007 | 04:05 AM
E-AT_me's Avatar
huh.. sounds about normal. hahahaaa...
first off, check your balljoints and all bolts to be sure everything is secure..
secondly, it sounds if you are "bottoming" out the front shocks. very common with these cars..
in order to get rid of this, you could buy the tein suspension, find a set of shortened konis, (very hard to do), or just raise the front up an inch for now. also, you can set the shock down in the fork another inch. just make sure it doesn't hit the axle. also, a guy on RPR made some camber plates. that should add about an inch of travel up top.
ef9itb
Jan 15, 2008 08:51 PM
05 600RR
Honda Motorcycles
Sep 3, 2005 05:08 PM
failed
Sep 1, 2005 05:25 AM
jond
May 5, 2003 01:24 PM
