Suspension & Brakes Theory, alignment, spring rates....
What does this sound like to you?? (pulling left)
Old Nov 24, 2007 | 07:24 AM
007EG's Avatar
Default What does this sound like to you?? (pulling left)
The trans has a stock LSD. The thing is that when i jump on it (but not hard enough to make the tires break loose) the car pulls to the left pretty hard..almost like it floats to the left. But when I let back off the gas it corrects itself and goes back to the right or center position. When i'm just driving normal and let the wheel go it goes very slightly to the right. But when i really get on it and break the tires loose the car goes straight. Why is the car pulling to the left? Is this just torque steer, and since the tires arent breaking loose the LSD is not needing to work and correct anything? Curious what your thoughts are and why it pulls to the left. Thanks for any help.
Old Nov 24, 2007 | 10:09 AM
007EG's Avatar
Default Re: What does this sound like to you?? (007EG)
bump
Old Nov 24, 2007 | 11:16 AM
MADMAX_zero's Avatar
Hit any curbs lately?
Might be alignment.
Old Nov 24, 2007 | 01:55 PM
007EG's Avatar
Default Re: What does this sound like to you?? (MADMAX_zero)
nope havent hit anything. I'm ok with the slight pull to the right. I understand that. Its the whole hard pull to the left only under acceleration but only when the tires arent spinning. Which is why i'm confused.
Old Nov 24, 2007 | 07:31 PM
007EG's Avatar
somebody....anybody??
Old Nov 25, 2007 | 03:17 AM
Mohsin's Avatar
i'd say alignment or possibly steering rack - check the tie rods for any play or worst case scenario the whole rack itself.
Old Nov 25, 2007 | 02:54 PM
007EG's Avatar
Default Re: (Mohsin)
I'll give that a shot, thanks. Anybody else with ideas?
Old Nov 25, 2007 | 04:04 PM
chrisw85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohsin &raquo;</TD></TR><TR><TD CLASS="quote">i'd say alignment or possibly steering rack - check the tie rods for any play or worst case scenario the whole rack itself.</TD></TR></TABLE>
this along with the rest of the suspension bushings and the motor mounts and motor torque mounts
007EG
Dec 15, 2007 04:41 PM
Matty.
94
Mar 16, 2004 09:53 AM
Bills01ITR445
Oct 21, 2002 06:39 PM
JLange
Sep 19, 2002 06:40 PM
